I have a mitsubishi vs-60603 and this morning it wouldn't show any video but i had sound. I unplugged my tv for several hours and now the screen is blue? Is there an easy way to reset the tv and make all the colors appear?
  • hintzjon Oct 11, 2010
    I just moved the tv from about 16 miles away. It seemed to work fine for a day or so. Can that board come loose? If so, can it be reseated? The red last night was out of whack then the tv wouldn't fire up this morning. Just wondering if that can still be the board issue or something that just isnt making good contact/
  • 11,800 Answers
A solid blue screen signals the fact that the image processor doesn't receives any signal - since the sound comes in normally then there's a bad connection inside the tv in the mainboard.
You will gonna have to take the back cover off, take out the mainboard and inspect it then - if it's ok, no breaks or bad solderings - put it back and reseat all the connectors in there.
It the image looks kinda ok but it's only blue then the red and green tubes aren't powered - open the back cover, take out the protection over the tubes and reseat the video final boards on the tubes.
Posted on Oct 12, 2010
  • 6,993 Answers
There is nothing to reset in a situation like this.
Connect your TV to a DVD player using a separate wire distinct from the one you used previously. If the TV does the same, then it means the video/display/picture board/card of your TV is defective, that's why its not showing any video.
Below is a picture of what your TV display board looks like:
Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it. You will need to replace the display board of the TV.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Oct 11, 2010
We lost power to the Mitsubishi Big Screen Television Model # VS-60603. I can't get the picture in a picture to shut off and I can't get the other options that use the TV to work such as the Wii, DVD...
IF SET will not go to inputs (they do not show) this model (circa 1998) does have a OPTION menu to do a hard reset with the Mitsubishi remote.
I have the information. Confirm model and I will tell you how to attempt this.
If this told you something you did not know, rate this solution and comment here and I will tell you how.
SD TECH
Sep 16, 2010 | Mitsubishi VS-60603 60" Rear Projection...
TV will not show a pic just sound but when movie playing can view
  1. Sounds like you have a video prioblem. But before you go spending money on a service call. Unplug the TV and take the back off. Next with a bright flashlight check the boards in the set for coolant fluid that has leaked onto the board. The fluid will be clear and kind of have a gel like feel to it. If you see it your set is unfortunately toast because parts are NLA (no longer available) Good Luck
Aug 23, 2009 | Mitsubishi VS-60603 60" Rear Projection...
Green power light on but no sound or picture.
When I press the power button it just clicks.... what. ... vs-60603 I will only stay on for a few seconds and then shuts off. ...
Mar 30, 2009 | Mitsubishi VS-45502 45" TV
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi vs-60603 lamp replacement
the VS 60603 has picture tubes three of them called CRTs you can get replacements at the following link.
http://servicemanuals.vstore.ca/
Aug 17, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi 60603
try switching your pip to the main screen and see if the pip shows blue while the main screen works.
May 29, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-60603 60 in pink spot
I have seen this before, and I can only describe it as a flaking of the phosphorus coating in one of the picture tubes. If you can, remove the back such that you can take a flashlight and look down into the 3 picture tubes. If you see any flaking or dark spots in the phosphor, there will be a spot on the screen missing that color. Unfortunately, this is not repairable, as all 3 tubes would need to be replaced (like replacing all 4 car tires when one is completely bald) and that would cost more than a new TV.
Jun 06, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Technical manual for Mitsubishi VS-60603
Yes there is! Go to http://www.servicemanuals.net and its available on a paper typre or instant download type for about $24.00. You can get parts nat http://www.partstore.com. Good Luck
Aug 29, 2006 | Mitsubishi VS-60603 60" Rear Projection...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
