Question about Briggs & Stratton Garden
Omega 42 petrol mower hunting then cuts out. Cleaned filter and plug still same
    Scholar:
  • 150 Answers
Check high speed adjustment on carb. Back it out (counterclockwise), if there is no adjustment screw the you may have to drop the carb bowl and clean, blow out jet with air
Posted on Oct 11, 2010
Why does my 6.5 hp kohler lawn mower keep pulling oil into carb air filter
Its to stop the dust blocking the filter. The filter should be cleaned with petrol every 4 to 6 months to remove the dust & oil build up, cleaned in/with petrol and re-oiled. Its also good to clean the filter housing each time you clean the filter
Sep 26, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
EFCO63C mower will not start after being left unused for 10 years
make sure you have spark, then check fuel filter, then fuel pump
Mar 08, 2013 | Garden
Craftsman 42
I had the same problem in my craftsman, the problem was in the choke. the spring was broken and it runs fine now after replacing the spring.
Aug 11, 2012 | Garden
Craftsman 18.5 hp, 42"cut, riding lawn mower quits running after 10 minutes
ONE OF OR YOUR COIL PACK...(UNIT PLUG WIRE COMES FROM IS PROBABLY DEFECTIVE
Jul 29, 2012 | Craftsman Garden
Doesn't start threw black smoke died now will not start
check the petrol filter,if it has shreaded it more than lightly has gone into the carb ,thus the carb needs to be cleaned out,it would be no harm to check plugs aswell but idsay the carb float and jet is blocked or partially contaminated
Jun 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman 15.5 hp 42 in deck lawn tractor starts up and will run for few minutes, then cuts out really bad and dies. I have installed a new spark plug, new fuel filter, cleaned the air filter, and...
Sounds like dirt or water in your fuel system. Have you drained the bowl on the bottom of the carburator? There is a small bolt on the bottom of the bowl; be careful not to over tighten it. If you find anything but fuel in the bowl you may need to drain your tank as well.
Apr 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray 20 hp
probally trash in the carb or fuel filter partially clogged. try replacing the fuel filter if no go the carb will need disassembled and cleaned.
Jul 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Nannie what can be wrong with my power devil petrol lawn mower the engine wont keep running then cuts out petrol and oil ok
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
122 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
