Hotpoint tcm80 aquarius - operating manual. I need to know how to clean the the thing at the bottom of the machine! Apparently it should be done every month or so and we've had it for 3 months but lost the manual
barkencoa
  • 3463 Answers
SOURCE: my dryer is going through the motions of the
It could be the element or a faulty thermostat.
The only way to be sure is to test them with a meter.
Hope this helps.
Posted on Jan 19, 2010
SOURCE: HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Posted on Feb 07, 2008
  • 1462 Answers
SOURCE: HOTPOINT aquarius WF541G
most likely suspect is the heater. undo wires from heater and see if fault persists. if not, heater is down to earth and will have to be replaced.
another possibility is a leak causing some of the wiring to be wet
Posted on Jun 29, 2008
  • 86 Answers
SOURCE: hotpoint aquarius washing machine water
Hi, Ok first things first where is your machines waste pipe connected? If it connected to the sink trap check there first by undoing it and check that there is nothing inside stopping it from letting the water out..?
If this is clear then have you lost anything? Sock? ETC....? Can you hear the pump? And is the water draining but not spinning?
If you cannot hear the pump running then it will more that likely be the pump as they are a magnetic pump which fail quite alot. If the pump is running then it is going to be something you have lost which will be located in the sump hose underneath the machine whic comes from the tub to the pump. Take it off and check and clean as nesscerary. Or last but not least it could be the fact it is doing everything but not spinning ( no drum action )? Check the motor carbon brushes if they are low then this will cause the problem or the motor has failed!....
Good luck and let me know ho you get on??
Posted on Dec 30, 2008
  • 100 Answers
SOURCE: hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Posted on Jan 27, 2009
Hotpoint Aquarius WML540. Want to know where the filter is to clean it.
Hi, you have to pry the bottom cover off on the machine, there will be filter access underneath, please CLICK HERE to read the manual, page 12 shows the filter location and how to access it.
Hope this helps
Feb 12, 2011 | Washing Machines
Where is the filter located on a Hotpoint Aquarius WM63 washing machine?
Remove lower rear panel of washer.
Locate and remove the large black hose from bottom of drum, remove and clean the filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Cloths are smelly even after wash on Hotpoint WD440 machine.Any suggestions
hi you may want to try this stuff , its american i think but now availabel in britain ( ebay)
affresh washer cleaner
Aug 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I need the operating manual for the Hotpoint aquarius wm32 1200 spin washing machine
In your main browser bar, type in------HOTPOINT.CO.UK
Click on-------AFTER SALES.
Then click on----DOWNLOAD INSTRUCTION BOOKS..
Enter your model number and download instructions.
Please rate my solution.
Thanks.
Nov 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WM62P will not operate.
yes.......could be the interlock.....
cheap part to try first..
cheers
Aug 03, 2017 | Electrolux Washing Machines
Hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Thanks.
Aug 28, 2009 | Washing Machines
No manual
HI. i have located the manual and you can access it via the link below. You can also print it out if needed.
CLICK HERE FOR THE HOTPOINT MANUAL.
Please rate and god bless:)
Apr 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WASHING MACHINE.
at back, take small bottom panel off. you will see a large diameter hose going from bottom of machine to the pump. undo this hose at the machine end and the filter is inside the hose. take out and clean.
be carefull, lots of water will come out if the machine has not drained.
best to disconnect from mains when you do this
Aug 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
