Question about Canon PowerShot A720 IS Digital Camera
Flaw on LCD monitor
This camera is 2+ months old, seldom used, it has pink stripes on the LCD screen, they do not show up in the image, but it distorts the view
    Novelist:
  • 130 Answers
This is normal. It may be distracting, but what it is is light. If you notice, it happens when there are bright spots, lights, reflections. These distortions will show up in video so try to avoid aiming at bright things while in video mode. Another type of flicker will happen mostly in florescent light.
Before CCD image sensors, video camera used tubes and aiming them at the sun or bright objects would burn the tubes permanently so cameras have come a long way, but by the nature of cameras being devices that record light, it is hard to eliminate that effect altogether (similar to red eye...just can't be a perfect science due to human nature of having blood vessels in the back of their eyes that when bright light is shined into them, their pupils open and the red color is reflected and shows up as red eye...this is best fixed in a photo editing program. It is hard to totally prevent, but changing angles and not shooting directly head on at subject helps). But I digress...
If it is really distracting for you, here is the one thing I found helpful; recompose the shot slightly by moving yourself, the camera, the angle (doesn't have to be dramatically different, but try to have the sun or light source behind the camera). As you move around, continue to push the shutter halfway down (each time not continuously) to bring subject into focus (getting your green box or boxes that indicate proper focus). Sometimes the lines will disappear if you change your shot even very slightly.
Hope this Helps!
Posted on Jun 01, 2008
Samsung L830 digital camera Has horizontal bands across still images past 1 month this is 2 year old camera
Sounds like you have a faulty LCD, or the backlight in the LCD has failed.
Check eBay for a replacement screen.
Please remember to rate my solution to show your appreciation!
May 31, 2011 | Samsung Digimax L830 Digital Camera
Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Dec 18, 2007 | Fuji FinePix S5700 Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Overall pink cast and pink stipe at top of all images taken.
Never had that camera, however, had the same problem -- the pink stripe and pink cast. Turns out the lens cover was slightly cracked and not opening and closing properly. Thus -- the pink cast.
Mar 26, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
LCD Monitor Half Screen Pink
sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Feb 10, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Canon PowerShot A720 IS Digital Camera Logo
113 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
