Question about Video Cameras
Tape Eject Problem
For some unknown reason (no abuse, careful care), my Canon Optura 20 will no longer open the tape compartment. When I flip open the casing (there are no cables or straps hindering the ability to open), the tape compartment clicks several times, then only moves up part way. It never makes it all the way up and the door does not flip open. There is no tape in there at the moment. I've tried with battery and with A/C power, but no luck either way. Any help would be greatly appreciated. By the way, this site is fantastic! Thanks!
  • erbell Feb 17, 2009
    I have the same problem with my JVC Compact Vhs C GR-800. It's very old but everything else seems to want to work,except for the power switch which doesn't seem to want to shut off.
I have the same camera and it just did the same thing.  Can't open it and its jammed.  Hope you find an answer, but my answer was to go out and buy a JVC 850 at Circuit City for 200 bucks.
Posted on Jun 02, 2008
Tape won't eject on Canon Optura 20 MiniDV. About
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jul 30, 2011 | Canon Optura 20 Mini DV Digital Camcorder
DV tape won't eject from Canon Optura 20. Power on, screen flashes "eject". Battery is fine. Tape comes up but won't release.
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Dec 18, 2010 | Canon Optura 60 Mini DV Digital Camcorder
Canon Optura Pi Mini DV Digital Camcorder. The metal compartment holding the tape won't open. Battery is charged, everything else works. Cannot remove the tape.
Tape mechanism malfunctions can be due to many factors. A bad gear is the most likely cause and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sep 01, 2010 | Canon Optura Pi Mini DV Digital Camcorder
Will not eject mini dv tape
I had the same problem. I cycled through the eject process until it finally gave me back my tape. I had to send it back to have the tape carriage replaced
May 03, 2010 | Canon Optura 20 Mini DV Digital Camcorder
Eject mechanism not functioning
Once when this happened to me, I took it to a repair shop and they said it just needed to be cleaned. (Optura PI tape won't eject)
    Dec 28, 2009 | Canon Optura Pi Mini DV Digital Camcorder
    Reads "eject tape" or "remove tape"
    Theres been a failure in the drive system for the tape. Probably mechanical, so you woul need to take it in to get fixed.
    A few times I've been able to resolve this by blowing compressed air in the frame and cleaning the head (if u can get to it)
    Aug 26, 2009 | Canon Optura 20 Mini DV Digital Camcorder
    Optura 20 worked fine yesterday. Now it repeats eject tape over &
    try laying it on its side and giving it a firm tap.....thats what other people have been doing an it worked.....we will see......
    Apr 17, 2009 | Canon Optura 20 Mini DV Digital Camcorder
    Canon Optura 40 playback - only get blue screen - no image, no sound
    Try a cleaning tape. Buy a good quality cleaning tape (Panasonic makes one) and remember: cleaning tapes are abrasive so don't overuse it! Overuse can result in the need to replace the rotating drum assy in the camcorder. I'll bet a cleaning tape takes care of your problem.
    Oct 25, 2008 | Canon Optura 40 Mini DV Digital Camcorder
    Canon MV500
    Perhaps this will help some. I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation applies to you, try the following, and make sure that in the future you don't fully rewind your tapes! Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, near the top (that is, opposite the side where the tape is exposed), locate the notch between the two spools (the "wheels"). The notch will have a spring-loaded slider inside, which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.) Hope that helps, and good luck. In the future, I'll heed the common advice to use the camcorder playback as little as possible, relying on a tape deck for RW/FFand making sure to transfer material to scratch disks ASAP and then just storing that footage away in a shoebox!!!
    Dec 11, 2007 | Canon Optura 20 Mini DV Digital Camcorder
    Cassette Jam
    The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
    Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
    Video Cameras Logo
    234 people viewed this question
    Top Video Cameras Experts
    Are you a Video Camera Expert? Answer questions, earn points and help others
