Question about Panasonic SC-HT40 System
My panasonic SA-HT40 it's saying overload and the turn off what can I do
2 Suggested Answers
jagesar
  • 9 Answers
SOURCE: when i turn my sa-ht40 on it says power overload
i have also the same problem with a panasoni SA-HT40. when i turn it on I see on the display OVERLOADED, and then thue unit turns off.
please help me
Posted on Jan 31, 2010
Its it's a Panasonic receiver sa - xr15 it keeps on saying it's overloaded and I got nothing hooked up to it right now
It might be down to the fact that the main power amp has shorted and therefore overloading the system. It can happen if say you had some faulty speaker cable, or two wires touched together. Or it can happen on it's own.
May 14, 2016 | Panasonic Audio Players & Recorders
I have an old Panasonic SA-HT40 surround sound system. When the unit is powered on the error message "F76" shows on the display and then the unit shuts off immediately. The user manual instructs to un
I have the same problem with my Panasonic model SAHT-40. I get the same code plus popping and shortly reads maximum overload then cuts off. I disassembled my unit and discovered that my fan fails 2 work causing the unit it over heat. I called Panasonic 2 place an order 4 a cooling fan. This model is obsolete they dont even manufacture parts 4 this unit anymore. The closest that I can get with my credit card is Samsung model AH31-00056B cooling fan through Panasonic. I hope that this solution helps all of u out with ur unit!
Nov 30, 2012 | Panasonic SC-HT40 System
Why is my panasonic SA-HE 200 receiver keep saying overload
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 08, 2011 | Panasonic SA-HE200 Receiver
Its panasonic sa-ht40 how would i fix this problem
If this is a reply to someone asking for more information, you didn't link this post to your last one, so this post would be like me saying right now "It's a Chevy, how do I fix it?".
Please post a complete and comprehensive question including the make/model/exact problem, when the problem occurs etc ALL IN ONE POST. Thank you.
Feb 22, 2011 | Audio Players & Recorders
We cannot get two of the speakers to work is there a certain mode it should be in?
Which two? There are al kinds of modes. The source may be stereo. See page 24.
Have you set up everything according to the manual?
http://www.retrevo.com/support/Panasonic-SC-HT40-Home-Theater-Systems-manual/id/356bh951/t/2/
Dec 26, 2010 | Panasonic SC-HT40 System
When i turn my sa-ht40 on it says power overload
please help me
Jan 13, 2010 | Panasonic SC-HT40 System
Overload & shotsoff
i cannot get sound as my ac receiver says overload what can i do
Apr 18, 2009 | Panasonic SA-HE200 Receiver
SA HE200 ~ Overload at power up
First of, be sure volume is turned all the way down before or as you are powering it it.
Second if that does not work disconnect all speaker, and input/outputs.  Power the device on and see if it says overload.
If it does skip the rest of these steps, your capacitors are bad or the power supply is no longer functioning correctly.
If it doesnt, start with testing each speaker at power up.  Match the speaker to the output it goes on, power the device see if it says it.
If it does on any speaker test it is a speaker issue or a terminal issue.  To test for terminal or speaker issue plug a different/ known to work speaker in that same terminal, if it doesnt say overload it is a speaker issue, if it does say overload it is a terminal issue.
Once you have made sure all speakers and terminals work correctly start plugging input and outputs in and test individually.
Jan 09, 2009 | Panasonic SA-HE200 Receiver
System is saying overload more frequently
Blow all the dust out of the unit with compressed air to prevent over heating (overload)
Aug 20, 2008 | Panasonic SA-HE200 Receiver
Panasonic SC-HT40 System Logo
475 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
