Question about Ricoh Aficio 1018D Copier
HOW DO I CHANGE THE DRUM ON MY RICOH AFICIO 1018 MFC
Push the green lock lever on the toner cartridge down, then remove the toner cartridge from the drum unit. Set the toner cartridge aside on some scrap paper. Set the old drum unit aside out of the way. You will need to order a new drum. Next open your copier machine and remove the old drum. Click on the link below to view the part needed:
http://www.worldclassink.com/Ricoh-Aficio-1018-supplies-printer10611.html
Posted on Oct 11, 2010
Help my Ricoh Aficio 1018 is showing sc 990
These machines want their drums/pcu at 150K. SC990 is usually a good indication of a bad drum.
Sep 02, 2014 | Ricoh Aficio 1018D Copier
Functional problem sc 390 on ricoh photocopier, despite replacing drum, developer,blade,gears. after removing 9 copies it reads functional problem.
SC 390 on an Aficio 1018 will most likely be a bad TD (toner density) sensor, if you've already replaced the drum and developer. (One thing to check quickly though is to pull the PCU out and reinstall it, just to make sure that connection isn't the problem.)
You can either replace the TD sensor by itself, or replace the DV unit (which probably won't be much more expensive). But either way, you'll need to install new developer when you replace the parts.
Aug 17, 2011 | Ricoh Aficio 1018 Printer
Horizontal streaks and smears across whole page. Still does this with lightest setting. Can't read copies at all. Model- ricoh aficio 1018
sounds like the recycling pipe is blocked or cleaning blade has worn out
You need to take the drum unit appart and vac out the recycling coil and clean the cleaning blade.
Nov 21, 2010 | Ricoh Aficio 1018D Copier
Ricoh Aficio 1018 printing lines, seems to be photoconductor
Cleaning the drum will not help. Depending on many factors including drum condition, number of pages printed etc, you will need at least to replace the drum cleaning blade. This is a common cause of black streaks. The drum should have been clean. The fact that it has toner on the surface is pretty good proof that the cleaning blade is bad. The part number for the blade is B0392289. I would do a search for this part and get one before you even think about trying to deal with the streaking problem. Once you get the blade, if you are mechanically inclined then replacing the blade is not difficult.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Ricoh Aficio 1018D Copier
Aficio 1018 cod.922
tengo una aficio 1018 me sale el codigo sc 922 que puedo hacer de antemano les agradezco
Apr 02, 2010 | Ricoh Aficio 1018 Printer
Error code sc500
Your main motor is hard to turn.. Check your Drum unit. Pull it out then on the back side you'll find a small agitator gear then tried to turn it. If it doesn't rotate then you might have to change its paddle gears, idle gear or that development sleeve is stuck. Hope it helps.
Apr 14, 2009 | Ricoh Aficio 1018 Printer
Ricoh aficio 1018 printer
yes you have to install the drivers and give the usb option for communication
Aug 05, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Printing rubbish
What computer? What Operating System? What type of connection to the 1018? What driver type?
Mar 24, 2008 | Ricoh Aficio 1018 Printer
267 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
