Question about Karcher K2.26 Electric Power Washer
Makes electrical humming noise but does not pump water
    Problem Solver:
  • 5 Answers
This is could be the capacitor that has failed. The capacitor gives the motor the initial kick in the right direction to get it started. You can confirm it is a failed capacitor and that the motor is still ok by flicking the fan blades with a stick in the direction it should spin just as you switch the pump on. The pump should run normally. You can get them off Amazon or ebay for around 5 Pounds (GBP)
Posted on Dec 01, 2011
Motor capacitor (located in electrical connection box) faulty. replace capacitor
Posted on Oct 19, 2010
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
What are the side effects over years of use
Ball Bearing needs to change.there is inside the pump a mechanic seal that with the time, leaks water and rust the ball bearing balls and making rusted the shaft .
The pump at this time gets Humming when works.
Pump humming or making noise is not a good working pump.
must be quiet without noise
Aug 19, 2014 | Pool & Spa
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Noise from the indoor unit of Mitsubishi MS09TW
My unit is a 3 year old Mitsubishi and it started making the humming noise you described. It is quite high and I finally got up on a ladder to have a look. It is the water pump making the noise in my case. It seemed like it was pumping a little too much water out. I undid a screw and angled the pump slightly and problem solved.
hope this makes sense and helps a little.
Jan 02, 2018 | Mitsubishi MS09TW Air Conditioner
My Electrolux washer will not drain water or fill water, it will spin. It is also making a humming noise
You need to check for the Humming noise as this can be the indicator to the problem, if this comes from the motor then the capacitor is faulty. Failure to switch on the INLET and the DRAIN pump can be related to fault in the control panel or this can also be due to faulty electric line voltage on the outlet.. So please check this out.
Also check the inlet and drain filters for clogging as a clogged drain pump can also hum.
Jan 12, 2013 | Washing Machines
Water won't pump out of Dishwasher.
if your hearing a hum then something is in a bind. i have found things as small as 1/2 inch of a toothpick being enough to hold an electric pump back. i suggest taking a very simplistic approach to this problem. find the obstruction and remove it. good luck.
Jan 29, 2010 | Bosch Dishwashers
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
Karcher K2.26 Electric Power Washer Logo
1,303 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
