Question about Hotpoint HSS25GFP Side by Side Refrigerator
The water dispenser is leaking - Hotpoint HSS25GFP Side by Side Refrigerator
  • ryanisready Oct 11, 2010
    The problem in this case is the water dispenser in the door. The water is dripping from the tube that shares space with the ice dispenser. It seems to be self contained, because the leaking continues with the door open, and defrosting doesn't help. I defrosted the unit and the leak continues. I wonder if I need to get inside the door?
    The water dispenser is leaking from the tube in the front door of the freezer. It leaks even after I've defrosted the freezer (which did not appear to need defrosting) and with the door open and apparently disconnected from the water supply. Do I need to get inside the door?
    President:
  • 1,216 Answers
It is common and the fix is simple. Do it yourself.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain ube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Here is a diagram of your freezer section.
Posted on Oct 11, 2010
  • 6,993 Answers
Visit the below link, you will find a video that will be of help in solving the problem. This is an advantage because you will be guided on how to fix the problem while watching the video.
Let me know if your need further help or if you are not satisfied with the video or if the video does not solve your problem.
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Good luck.
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water leaks out of the dispenser
Hi
Under some circumstances the water dispenser can leak water into the spill trap when not in use. This problem could be caused by one of several scenarios involving the installation of the refrigerator doors. Small leaks are often triggered when a new water filter is installed. The exact location of some parts will vary depending on your model of refrigerator.
Keep a glass under the dispenser for up to three seconds after releasing the lever. The water doesn't cut off immediately, and there may be a few remaining drops in the system. This is normal and doesn't need any further attention.Run the water dispenser into a large container for three minutes. Empty the contents of the container down the sink. A newly installed water filter may spurt or leak water from the dispenser until the water is run for a few minutes. Some dispensers may cut off after a few minutes automatically.
Run the dispenser intermittently -- five seconds on, five seconds off -- for two minutes. This measure clears air trapped in the supply line, filter and dispenser system. Some dispensers will spurt or leak water until all air is purged from the system. You should follow this step each time the water is disconnected or the filter changed.Ensure all components of the water supply have been properly connected. All connections should be tightly screwed in place and pipes straight so water doesn't leak out of the pipes or dispenser nozzle. Contact a technician if you didn't install the refrigerator yourself.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Refrigerators
Kenmore 253.52632200 refrigerator water dispenser leak. The water dispenser in front of the door leak water slowly. Sometime it leak a lot and sometime it does not leak
You need to replace the water dispensing solenoid valve located in the back of the fridge and your problem will be solved.
Dec 12, 2010 | Kenmore Refrigerators
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
The water dispenser leaks
The most likely reason for the leaking at the water dispenser is the dual water control valve on the back and near floor is leaking water while shut off. The only option is to replace the water control valve. Sea Breeze
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
The Water dispenser is leaking water
It's either a bad water valve or the switch in the dispenser is stuck.
Oct 19, 2007 | KitchenAid KSRG22FK Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
42 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
