Question about Kenmore Grilling
Gasgrill I grilled recently and the right knob melted right off and flame came out where the knob was .Part of the front is burned. this Grill is only 2 years old. can I replace the knob only will this be safe?
  • soine18 Jun 01, 2008
    Thanks for the tip i will do that
    Champion:
  • 254 Answers
No you need to replace the valve behind the knob as well most likely this is what caused the flame.
Posted on May 31, 2008
Flames coming out of front of two burner on Charbroil Commercial grill
you have a gas leak on the control knobs soap test to see where the leak is. use washing up liquid and water to check for leaks .
Jul 24, 2016 | Grilling
Grill worked fine for almost a year but I recently used charcoal following the directions in the manual (and it worked great). However since using it (& it is long gone), if I turn grill on high,...
Kathleen, the ash and debris left from the charcoal clogged the burners and caused the flames to shoot back thru the venturi valves, which is causing the flames to reach the control knobs. For the most part. I would suspect that the control panel, the electronic ignition, control knobs, the gas manifold for the burners and the burners are now completely shot.
Now, you're at the stage of determining is it worth it, to replace all the parts (if you can find them) and repair the grill. Since you didn't mention who the manufacturer of the grill is and how long you've had it. I have no way to tell how much it's worth. But, if it were me, and the grill is at least 5 years old and it originally cost $600.00 or less, I'd seriously consider replacing the gas grill with a new one. And if you want to do some charcoal grilling, get a separate inexpensive charcoal grill and take good care of it. During the weekday evenings when you don;t have time for charcoal grill to preheat, use the gas grill. On weekends, use the charcoal grill if you like.
Hope this helped answer your question and ultimately help you make the right decision.
Apr 26, 2011 | Vidalia Grilling
Flames shoot out the front of charbroil grill melting the knob
maybe put the barbecue in different place more out of the wind
Apr 27, 2010 | Char-Broil CharBroil Master Flame Gas...
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
Flame problem
check the holes the flames come out of, they may be clogged, you may need to clean with a wire brush, if rusty then replace the burners. easy to replace
Sep 25, 2008 | Thermos QuickSet 462836203 (LP) Grill
Gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Aug 05, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Grilling Logo
553 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
