Question about Pulsar Sport PXD533X Wrist Watch
How to i set the month, day on my watch - Pulsar Sport PXD533X Wrist Watch
    Genius:
  • 1,970 Answers
Mcdevito75 here, By pressing the MODE button until you come to the month and day.
Posted on Oct 11, 2010
How do I know what month my Michael Kors watch is showing?
At the end of a month that is less than 31 days you must manually advance the date.
Aug 30, 2014 | Michael Kors MK5629 - Sport Bradshaw...
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
How do I set the date on this watch. Can set the month, day and time but not the date.
mcdevito75 here, You may have to go thru the entire 24 hour cycle to change the date, then re-set month and day. Depending on what kind of watch you have.
Nov 19, 2010 | Watches
How do you set the day and month?
Mcdevito75 here, The stem on your Timex shou;ld have two (2) positions, slip a finger nail just under the crown and gently lift to the first position, it may take a little practice to get but you will. In this first position you"ll see by turning the crown one way you can change the date (number) and turning in the other direction you can change the month or day, if so, set the day and date to one (1) day before the day and date you want. Push the stem back in and lift the stem all the way to set the time of day, now cycle thru the watches 24 hours to set the day and date you want. Your Timex is now set and will change at the proper time of around midnite. If your Timex has the month and day you may have to cycle the 24 hours to reach the correct month other than that these instructions should help.
Aug 09, 2010 | Timex T21553 Watch for Men
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
I have a etica watch au9101 I don't know how to set the month and if it takes a battery when i got the only thing I got was a 5 year warranty card with ( no owner manual) Thank you
As I can see from the picture here:http://www.etica.ch/banner/AU9101.jpg your watch do not need a battery as it is automatic/selfwinding mechanical watch. There are two push buttons on the side. One of them is for month setting and another one for day setting. Use small pin or ball point pen to push them. Try both and you will see which one is for the month and which for the day setting. Push repeatedly until the desired month and day is set. Date in small window can be set by winding crown. Pull out crown half way out and set the date, then pull out crown further out to the time setting position and set the correct time. Push the crown back in and wind it back and forth at least 15 times to start the watch going. Before you start any of adjustments, set the time to 5.30 (am or pm - doesn't matter). It will prevent accidental damage of day/date/month mechanism. Rate me, plz.
Feb 28, 2010 | Watches
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
Jan 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Pulsar Sport PXD533X Wrist Watch Logo
42 people viewed this question
Top Pulsar Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
lessaleadr
Level 1 Expert
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
