Question about Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher
Kenmore 587 model dishwasher produces water but won't spray or move from bottom
We have a 2 year old 587.15142400 model dishwasher. Water is coming in at the bottom but no water is moving up through the sprayer. No dishes are getting wet and detergent is just laying on the bottom. Any suggestions of how to fix this? Thanks!
  • 4 more comments
  • Anonymous Aug 26, 2008
    Having the same problem. I noticed that the dishes are getting very hot, and the sprayer at the bottom has melted in places, but no idea why it isn't spraying.
  • solarfinder Sep 17, 2008
    My sprayer just melted in place as well. After I replaced the sprayer, I noticed that the sprayer was not spraying water. I looked at other items, and tested the wires going to the motor and they were rating at 117 volts, however, the motor still wasn't working. The motor worked just fine prior to the meltdown, so my question arises, is there some type of solenoid or inline fuse that controls the voltage on the motor that can be replaced or reset?
  • Anonymous Nov 04, 2008
    Same here. Time to get a new one.
  • Nancy Cummings Feb 18, 2009
    Our Kenmore 587 dishwasher has the same problem. Not sure what to do.
  • bmc4810 Mar 15, 2009
    Having he exact same problem as the others posting here. The detergent just lays on the bottom, dishes not getting wet, dishes get VERY hot, and there is a loud whining noise.
  • Anonymous Mar 21, 2014
    where is the drainline on kenmore dishwasher model # 587
Top washer arm not turning
Posted on Sep 29, 2008
We have a Kenmore dishwasher model 587, It is about 4 years old. Water is coming in at the bottom, but water is not coming up throught the sprayers. Detergent is just laying on the bottom. The dishwasher also gets stuck during cycle.
Posted on Feb 18, 2009
I have a 587-15142400 Kenmore dishwasher that leaves soap on all the dishes. Is there anything we can flush out our dishwasher lines with?
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Mar 04, 2011 | Dishwashers
My Kenmore quiet guard standard model 587-15152400 is not getting the dishes clean AT ALL. It has hot water, water is draining, have not changed soap. Don't know why?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Bottom Spray Arm Not Rotating
check to make sure you are getting enough water entering the dishwasher. If you add a liter of water, does the water arm turn then? If so, you may have a faulty water valve that is not allowing enough water to enter to turn the spray arm. Hope that solves it :)
Feb 26, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Standing Water in my Dishwasher
hi this is the electric pump thats in your dishwasher. its probably seized up.remove and clean it just might be dirty thanks the appliance doc,
Oct 15, 2008 | Kenmore Dishwashers
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
I have the same problem with dirty dishes on the top shelf and the utensil baskets
Dump the Kenmore on the seller's doorstep - when the place is full of customers!!
Dec 27, 2007 | Kenmore 24 in. 16264 Built-in Dishwasher
Kenmore 587
I think you are right. That would be the most obvious answer. Some motors are warrantied for 2 years or longer.
Nov 02, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 587
You may try the rubber gaskets and fasteners that attach your heat element through the bottom of the dishwasher body. This is the only full penetration of the shell involving metal that I see. You could see these fasteners if you remove the dishwasher from its current position, rotate it clockwise on its side and see the two cheapo pressed metal nuts on threaded studs that have wires attached. These keep that black metal loop on the bottom (inside the washer) in place. Remove wires, unthread pressed metal fasteners, check heater element for the rust issue (replace if needed) and reinstall new rubber gaskets and fasteners. Hope that helps!
Oct 09, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher Logo
1,611 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
