Question about GE WBSR3140DW Top Load Washer
GE model WWSE5240DOWW top loading washer, goes through cycle to rinse light and stops with loud hum from motor. Machine will not empty. Resetting code and running through lights sequence, it occasionally will access spin cycle, machine will spin fast and stop when lid is raised, but still will not drain. Blocked pump ?
5 Suggested Answers
  • 57 Answers
SOURCE: Humming noise during spin cycle
call a repair man and have him change the drive block. it is about 30 for the part
Posted on Feb 16, 2008
SOURCE: GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Posted on Apr 09, 2008
  • 4 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
Posted on May 30, 2009
  • 410 Answers
SOURCE: ge washer quits filling and spinning mid cycle
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer, a front load washer, or a dishwasher, I suggest you
go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as many other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you to a place that will help you solve the problem. Good luck with it.
Posted on Dec 07, 2009
Kenmore Washing Machine Belt-driven, top loading Model 110-8228310 Stock # 22831 Machine was over- loaded. Machine Stopped in Rinse Cycle did not empty water. Cleared load. Made New loads, machine...
I'm surprised the main breaker didn't trip or fuse blow as the washer has obviously demanded a fair amount of current to 'slightly' melt the end of the cord!
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. It could be the main motor, following the overload, or drain pump/motor as primary cause followed by damage to internal wiring/plugs sockets, I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 27, 2011 | Washing Machines
Machine didn't empty water after rinse cycle. Now
Check for power at socket using a lamp. If nothing, check the breaker for that circuit in the house electrical panel--push OFF, then ON. If now get light, try the washer again. If you get a loud hum from the machine, it may be a locked motor. Pull the plug again and check the motor. The tub can be drained by lowering the end of the drain hose below the interior water level.
Aug 01, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
May 28, 2009 | GE WBSR3140DW Top Load Washer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Apr 09, 2008 | GE WDSR2080D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
138 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
