Question about Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor
Pressure switch broke off - Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor
Where do the wires go to the pressure switch
Posted on Aug 08, 2012
My elmglo airmate hand held wont turn on relay switch wont work
the relay switch is the air pressure switch to turn the compressor on and off after reaching set air pressure; most have a button it. also just may be broke..
Sep 02, 2015 | Cars & Trucks
Craftsman air compressor will not shut off
w/o other details, one can only presume that the tank pressure switch has be adjusted to high or it has failed/broke. Adjust pressure downward (if not already). Replace tank switch.
Oct 09, 2014 | Craftsman Air Tools & Compressors
Pressure switch broke off-need help fixing
Sears.com
Parts direct
Look it up by model number
Then part discription
And they will send you the part for a fee
Mar 18, 2010 | Dryers
Can't get pressure from homelite hp3127s gas pressure washer after using only 1 season. can't find manual to find problem. is there a switch i'm missing?
No,it's probably a bad valve body or the pump itself broke. Homelite isn't the best quality machine.
Jul 14, 2009 | Garden
Pressure switch goes on and off
Ckeck the air pressure in your pressure tank. If it spit out water your bladder is broke and you'll need to replace it. If no water shut your pump off ,drain your tank and set yuor tank pressure 2 pounds lower than your low pressure setting. so a 30/50 pressure switch your tank pressure should be 28 psi
Jun 27, 2009 | Plumbing
I broke the red on off switch, on my preasure switch
IF YOUR TALKING ABOUT THE ON/OFF SWITCH ON YOUR PRESSURE SWITCH JUST REPLACE THE PRESSURE SWITCH WITH A NEW ONE FROM ANYWHERE - ONE THAT HAS THE SWITCH ON THE SIDE. TAKE YOUR OLD PRESSURE SWITCH WITH YOU TO MATCH IT. IF IT HAS SOME FANCY SWITCH MADE INTO THE COVER YOU CAN ADD THE PRESSURE SWITCH WITH THE SWITCH ON THE SIDE OR JUST BYPASS IT ALL TOGETHER. IT DOESNT EVEN HAVE TO BE THERE, THE COMPRESSOR WILL SHUT OFF AT CUTOFF PSI ANYWAY AND YOU COULD UNPLUG IT TO KEEP IT FROM RUNNING WHEN YOUR NOT USING IT. THE PRESSURE SWITCH W/ ON/OFF ON THE SIDE IS VERY AVAILABLE. HOPE THIS HELPS, JODY
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My top loader washing machine is leaking when filling
your problem could be from the water level pressure switch, ( selector of water level ) or from the pressure hose, in most cases the hose that goes with the pressure switch is clogged with dirt.
you need to open the unit and find the single hose that connects with the switch, in some cases it is usually clogged from the bottom, cut it out and make sure to leave some room not to over streched the hose,
the switch rarely broke, it is usually the hose, (transparent)
Jul 15, 2008 | Whirlpool Washing Machines
Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor Logo
147 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
