Question about Toro Garden
My lawnmower which is a TORO 6.5hp-Tecumseh engine won't start. When I pull the cord the valves start to move but on the second pull it seems to sieze up and blow some vapor out the exhaust.It ran fine last week...any ideas?
    Scholar:
  • 150 Answers
It sounds like hydraulic lock. The carb is dumping to much fuel into cylnder. Pull the plug when it feels locked up and pull again, if it blows gas out of the plug hole you have carb problem. Maybe needle is ****, maybe float has a hole in it and is sinking causing flooding.
Posted on Oct 11, 2010
Testimonial: "Thanks,my inlet seat needed repl. "
No compression when I pull the cord on my lawnmower Briggs and Stratton. What do I look for and how do I fix it?
There could be a whole bunch of things to cause this, from a badly worn engine to just a valve stuck open, a dealer could do a leakdown test on the engine and give a more definate reason for the problem, or you could remove the cylinder head ( side valve engine ) and check the valves are opening whilst turning the engine.
Aug 03, 2013 | Toro Lawnmower 20099 Mower Mowers Lawn
How do I take the pull cord wheel and spring off my Tecumseh Vantage 35 to replace it
There are little metal tabs that hold the wheel in place, bend these out then the whole assembly will come out. When replacing use the other tabs and wind the spring in, line up the cord hole then insert the cord, tie knot then release.
May 02, 2013 | Tecumseh Garden
Try to pull cord but seems seized on my self propelled lawnmower
Look underneath at your blade - it could be bent and hanging up. If not, remove spark plug and try to pull starter cord. If it won't move then you may have seized the motor and a new mower may be in order.
Hope this helps!!
Nov 16, 2010 | Toro Lawn Mower With Toro Power Tools
My toro lawnmower (brand new) it doesn't start.\r\...
The drive shaft might just need to be oiled. Turn the mower over and locate the drive shaft, where it goes from the mower's blade up into the body of the mower. Lubricate the area of the shaft that disappears into the body with WD-40 or another lubricant, then turn the blade by hand (be careful!) and squirt some more oil.
Eventually the blade should become easier to turn, and then your pull cord should extend without getting stuck. Good luck!
May 20, 2010 | Toro Lawn Mower With Toro Power Tools
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
Toro 6.5 lawnmower wont start when you pull the cord it comes out about an inch then it locks where you cant pull it no more
Remove the plug then try and see if you can pull the cord any futher.If not you may have to dismantle the pull start and check the clips are not jamming.
Jul 06, 2009 | Toro Lawn Mower With Toro Power Tools
Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
My lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Apr 12, 2009 | Garden
Garden Logo
612 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
