Question about Armitron Two Tone Sports Watch
I have an Amitron 20/1143D that isn't working. I've had it for three years. I replace the battery two months ago thinking that would solve the problem but it continues to go slow and lose time. Is it worth my while to get it fixed or should I just get a new one.
Died
i would suspect it needs a new battery you only got it 2 month ago but the battery could av been in a couple of years..
Feb 13, 2013 | G Shock X-Large 8900 G-8900A-1 Watch -...
Can i change my watche ?
it is still under warranty
contact the ,manufacturer customer service and ask how to get a refund for the faulty item under warranty
Jul 10, 2017 | Omega SeaMaster Watches
How long should a bulova watch work ---my husband bought me a bulova watch 7 years ago ----it stopped working & I thought I just needed to replace the battery ----so I did but less than 3wks later the...
I would expect the battery to last more like 3 years than three weeks.
Did you replace the battery yourself? If so, are you sure that it's the correct one correctly fitted? Did you use a quality make of battery?
I've known people to use metal tweezers to fit batteries - the risk of shorting the battery is very high with the result that battery life is seriously reduced.
Look at it this way - the watch cost you over 300 bucks, so it's a decent quality watch. Take it to a professional to have a battery fitted - it's not worth the risk doing it yourself if you're not completely sure what you are doing, and if the battery they fit fails then you can just take it back to them to sort out. Having a battery fitted for you should not cost a lot of money - but if you have somehow damaged the watch by trying to do it yourself then it will have been a very expensive way to save a little money....
Oct 14, 2017 | Bulova Diamond Watches
I bought a puma watch for myself about 1 month ago from Jeddah, Saudi Arabia but today it just stopped working by itself. What should I do now with it? Could it be a battery problem maybe? I live in...
yes it is the battery problem, any service center accepts battery replacement, find one on your loation. i hope i had been helped you.
Sep 11, 2011 | Puma Watches
I have had my MTG900 for about two years. About a month ago I noticed that the blue light would come on by itself. This happened every two or three minutes or so. Now my watch is dead except for the word...
All you need is to find the nearest watch repair shop. Ask them to replace capacitor (in case if your watch is light powered). If it's run on battery - replace by new one. It is very hard to guess what's the MTG900 is. Next time you are here, plz give:Make, model, ALL the writings on case back and every detail you know.
Feb 05, 2010 | Casio Atomic-Solar MTG900 Watch
My techno marine watch is not working. The battery was changed two years ago but the watch is only worn on special occasions. do you think it needs another batter. It is the diamond faced version.
That's right- your watch needs battery replacement. No matter you wear it every day or just once a year - battery life comes to an end in a two years time approximately. Expect the same all over and over again.
Rate me, plz.
Jan 07, 2010 | TechnoMarine Watches
How to replaced a eco drive battery
The ECO series of Citizen's do not require battery replacement, as they are solar powered. If the watch stops due to a long period of non-use, there is a procedure in the manual as well as the Citizen website on how to get it running again. You will have to expose it to light for several hours (but not with lots of heat such as a car dash) to get it running. If you continue to have trouble, you may have a problem with the watch. I bought my wife a ladies ECO drive about 8 years ago and bought one for myself about 2 years ago and have not had a bit of problems with either. They are extremely good watches and it is nice not to have to worry about "when will the battery die?"
Jul 09, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Battery Life: I have had my Garmin Forerunner 50 for only 3 months and the 2nd battery is already dead. Normal?
There is a fault with Forerunner 50's - I replaced my battery three weeks ago, after three months of average use. It posted the "LoBatt" sign again the following day. Garmin offered to replace it with an overhauled product but I've gone for a refund instead.
Jul 08, 2009 | Garmin Forerunner 50
Screen not working T Touch Titanium (Totally Useless)
I suggest you have to find the decent watchmaker and do not use dealers services anymore.In my opinion you have been overcharged in both cases.
Consider replacing touch screen if it is damaged and then sell it on ebay (anyway you do not like it). For watch in working order you have to get quite a decent money. If you gonna sell it as it is, you will get pennies only.
Later just buy another make and forget about this unlucky example. :))
Dec 07, 2008 | Tissot T-Touch T33159851 Wrist Watch
Armitron Two Tone Sports Watch Logo
347 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Bill Boyd
Are you an Armitron Watch Expert? Answer questions, earn points and help others
