Question about Compaq Armada 1592DMT Notebook
I cant reach the bios setting
While i was trying to change the existing ram ( EDO 64 MB ) , my old compac 1592dt cant boot as normaly , and a message appear ( non system disk or disk error ) .
i was checking my hard disk and it's ok .
i think something on bios was changed . but i can't enter to the bios setting .....
    Guru:
  • 1,342 Answers
It should be the F10 or F11 key.
Check HERE for more help.
Posted on May 31, 2008
Asus mb wl300 amd 64 4000+ won't boot to bios.
To make sure it isn't anything else, pull all cards, and drive cables from the board so the only thing left connected is the power connectors to the motherboard, the speaker, and the power button. Pull all the ram cards.
Now power up the computer. If you hear a series of beeps then the computer recognizes there is no ram on the board. At this point I would take the power supply out and have it tested. If you do not hear a series of beeps I would still have the power supply tested as it could be the 12v is fine but the 5 and 3.3 volt side is bad.
If power supply tests good then I would replace both the motherboard and processor. You take a risk of burning a new processor if it's the motherboard causing the problems.
Jan 08, 2010 | ASUS Computers & Internet
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Asus motherboard p5b-mx wifi won't display vga
this can be caused by a number of issues the leading being RAM (no post beeps at all). before you do anything else pull all existing RAM and install a KNOWN GOOD STICK in their place and try again.if that doesn't work try resetting the mb (see the owner manual on how to do that) bios settings to defaults (this generally selects onboard video). if you have an installed video card within the system also remove that (even though you aren't using it). is that memory compatible you have there with the board? if its too slow the stick may be fine but mb may not "think" so. do you have keyboard "flash"? is the hard drive indicator constantly lit? how about cdrom drives and/or floppies? can you eject same? all this points to incompatible or "bad" memory as the main culprit.
Dec 12, 2008 | Computers & Internet
ECS A535 Video Memory
You can only change the amount of video memory if your model has a videocard memory that can be dynamically changed. You're correct that it can be done, but only on specific models of notebooks. :) If you're not able to find it on the BIOS then your model might not be one of them.
Sep 21, 2008 | EliteGroup ECS A535 Notebook
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Gigabyte mb wont recognise dual ram
please check in bios for dual boot option.plz note for dual - channel configuration your ram should have same frequency and speed.
Apr 21, 2008 | Intel Motherboard
Re: Bringing new life to Accient Acer Laptop (AAL) Extensa-367D
bios updete can do pto alimit it cannot convert 1.1 usb to 2 or support more memory . contact any service cenetr to get hel[ful advice and bios update
Oct 15, 2007 | Acer Extensa 367D Notebook
Open Questions:
Compaq Armada 1592DMT Notebook Logo
89 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
