Question about Refrigerators
The frdge came with tubing iside ( a lot of it) is this what we use?
    Sergeant:
    Champion:
  • 351 Answers
Hi that the coil for the cold water depressor don't remove it supposed to be there jim
Posted on Oct 12, 2010
When u pull trans, we are stuck trying to get the shifter adapter out so we can get trans apart to look iside
it likely has to be pulled from the inside, when you remove the pan you should also be able to see inside the transmission a lot better
Mar 01, 2015 | Cars & Trucks
My AC is not working but a mechanic told me that need anew frdge
You need a blend door and blend door actuator I assume as it is the most common repair, If you use the factory parts the job takes all day and requires the dash to come out, there is a clever kit called "Heater Treater" that allows you to forgo removing the entire dash, If you click HERE it will take you to a video on YouTube that shows the job in total. The Heater Treater kit can be had on Ebay for about $100.00 last time i checked. I also directly attached the video below.
Feb 07, 2012 | 2006 Ford Explorer
Leaking please help. I need to order a new one that is 120v 60hz 15w s-86
My experience if I understand when you say "Leaking" Is that into the inside bottom of fridge?>
If so on auto-defrost(frostfree) frdge. the tube in back outside &attached to the freezer is cloged and wont allow condensation to disperse into the pan below therefor it leakes to the inside instead. Try unclogging by pouring Verry Hot water into back of freezer{inside}.
Apr 13, 2011 | Refrigerators
Where is the water pump located?
If its a 4 cyl. it is pass side front of engine on side down low. have to get at from bottom. If its v6 it is on the iside of timing belt assembly and runs of of that system must pull covers off to get to.
Feb 12, 2011 | 1994 Plymouth Acclaim
The drain tube in the freezer drawer compartment was clogged --we cleared it---where is the water supposed to go
There is a pan underneath the frdge that evaporates the water...
heatman101
Aug 29, 2010 | Sub-Zero 601R
It is defrosting but ice forms at the top of the drain tube and the water runs down to the bottom of the freezer and piles ice up. The drain tube is not stopped up. This is the third time I've thawed it...
If this is a no frost Frdge then you have problem with the timer and heater . If not you have a thermostat problem this could be another issue wherrein you fridge is going on continuosly. Increased opening of the door will assist in the frost build up. So try toreduce the thermostat , watch out if the fridge shuts off after about 2-3 hours of running. keep reducing the thermostat till you confirm it is working.Keep the frideg also a little away from any side walls to allow the heat exchange for better performance. Good luck
Jun 28, 2010 | Refrigerators
Leakage on drivers side floor board
Cold, too...
The A/C drain tube is clogged.
Raise passenger side with jack & support. or use ramps.
There is a tube under the firewall. Use a straighted-out metal coat hanger (corkscrew end) to clean out.
Have a dry towel handy ... your face will get wet.
Oct 05, 2009 | 2002 Mitsubishi Eclipse Spyder
GE frdge model ctx21eazhrww has water accumulating under lower crisper drawers and spilling onto floor
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 20, 2009 | Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
