Question about Sansui RZ-5200AV Receiver
I have a Sansui receiver Model RZ-1000. The left channel is out. Cheaper to repair? or just buy another similar on ebay?
I have this unit. It is built with disable links for each of the channels, which are easy to replace. The replacement part is only a few dollars.
Posted on May 18, 2011
  • Stumongo May 18, 2011
    That's *fusible*, not 'disable'...
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
How do I connect Subwoofer in sansui rz 5200 av model receiver?
You could refer to the instructions presumably available for the unnamed sub. THAT would determine the methods it can use.
Aug 17, 2011 | Sansui RZ-5200AV Receiver
I am fixing a sansui rz-5000av receiver /amp. the problem is the power supply,it does not switch on. the fuse is fine, capacitors are all ok. But power does not reach connector for the standby supply to...
So you're saying ac doesn't get very far into the unit. THAT should be easy to diagnose with CARE since ac is usually passed unmodified to the fuses and power supplies, maybe through a relay. Get a digital voltmeter and find out where it disappears after getting into the unit.
Dec 31, 2010 | Sansui RZ-5200AV Receiver
I have a sansui stereo av receiver rz 7000 from 1990 which works on 110 220 230 volts and the receiver has a voltage selector on the back - I need to understand how to move the selector from 220 to 110...
Remove the fuse cover with a flat screwdriver, then pull the surrounding circular black plastic piec straight out and reorient it to show the desired voltage, then plug it in, insert the fuse and cap.
Nov 24, 2010 | Sansui RZ-8150AV Receiver
Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
May 25, 2008 | Audio Players & Recorders
1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Nov 10, 2007 | SansuiM1315 TV
Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Sep 01, 2007 | Audio Players & Recorders
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Feb 01, 2007 | Sansui RZ-5300AV Receiver
505 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
