Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Not generating any steam - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Oct 29, 2010
How do I fix ultra steam mop model s-c393 that will not produce steam
The steam generating element may have failed, in which case it would have to be replaced.
Oct 03, 2016 | Ultra Products GarryTM Ultra Light Vacuum...
Tip
Shark steam mop not producing steam
It is a design flaw having a check valve orifice built into the steam generator.<br />The plastic sleeve gets hot and get hard and shrinks enough to cause blockage at the inlet to steam generator.<br />Also a lot of sediment builds up inside steam generator from impurities in the water which eventually causes a problem and block at the mop head.<br />solution would be to move the check valve from the steam generator to the pump discharge line where it is cooler. and use only distilled water. they should also use a stainless heater element instead of pot metal as it corrodes.<br />
on Apr 24, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
What kind of water is to be used in the steam station RHST 100. I mean to say that only distilled water is to be put or ordinary tap water can be used ?
hi.
distilled or de-ionised water is recommended in all steam generator units.
tap water can contain minerals and salts that will remain in the unit and fur the inside of the steam generator.
if you live in a soft water area where there are very few impurities in the water you should be ok to use the tap water.
if you are in a hard water area, do not use tap water.
the best way to work it out is look at the inside of your kettle.
if the inside is clean with no sign of scaling, the water should not scale your steam generator.
if there is any sign of scaling, do not use tapwater for your steam generator.
distilled or de-ionised water is recommended though
Apr 08, 2011 | Vacuums
I have a swan steam generator model s14021 and its all working but when you press button to get steam water pours out!
Dont know the model ,but steam is water and if water pours out than the steam heat portion isnt getting hot . Probably a heating element out
Feb 17, 2011 | Vacuums
Shark floor steamer does not generate any steam and water just drops
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Oct 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I am looking for a cap for my tefal pressing profile steam generator iron model 2880 can you help
Did anyone help you with this? Did you find - I also need one!
Sep 27, 2010 | Vacuums
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
59 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
