Question about Maytag MZD2766GES Side by Side Refrigerator
Freezer and frigerator side not cooling
Found burnt relay very badly. I replaced with new relay and overload and still not giving me cool air on both side.needs help.
  • James Helmer
    James Helmer May 11, 2010
    Is the compressor running after the new relay was installed?
Defrost limit switch location on Maytag Model # MZD2766GEW
Posted on Sep 26, 2008
    Champion:
  • 210 Answers
Whats the amps from compressor?
Posted on Sep 15, 2008
The frigerator & freezer are not cooling properly . i hear the compressor running . i have also diconnected cleanned inside and out but still the unit is not cooling properly . even on higest settings
If the compressor is running almost all the time (and the compressor sounds ok - no pinging/clunking),
then your side-by-side has developed a coolant leak.
When a system is low on coolant, the thermostat detects the warm condition of the refrigerator, and
runs the compresor motor in an attempt to cool off the refrigerator compartment, but if there's little
or no refrigerant in the system, the system's attempt to cool off the refregerator/freezer will fail,
with the symptom that the user wil hear the compressor motor running constantly.
May 13, 2011 | Kenmore Side by Side Refrigerator
I have a frigidaire side by side #FSC23LR5JM2 that is not keeping cool enough. Age is aprox 1.5 yrs. Noticed the problem over a couple of days. Turned the temp cooler by 2 numbers in the frig and freezer,...
if the freezers staying cold but not the refrige section,then its the damper vent door between the freezer and refrige section thats either frozen shut or the damper door motor is bad or without power,if nothings cold as in freezer and refrigerator sections,then its the ptc overload & relay on the compressor thats bad,unplug the ptc overload & relay off the side of the compressor and obtain an exact replacement and plug in the new replacement and it will again cool
Mar 23, 2011 | Frigidaire FRS3R5EMB Side by Side...
My freezer and refrig stop cooling. Both went at
You have a bad overload / relay on the compressor and incorrect model number so I cannot give you the part number you need .
May 29, 2010 | Estate TS25AFXK Side by Side Refrigerator
Compressor kicks off on overload/relay. Even after replaceing overload/relay and cap. It will run ok for a week if you let it cool down.
This is often found in small compressors when they heat up too much or too often. check to be sure the condenser coil is clear and has good airflow. If so and it still trips on overload then the compressor is bad. Hope this helps. Good luck.
Mar 23, 2010 | Amana ARB8057CSR Bottom Freezer...
IT WILL NOT COOL OR FREEZE, DIGITALPANEL IS SHOWING 52 TOP AND 39 IN FREEZER. FANS ARE GOING BUT NO COOL AIR NOR IS THE FRIGERATOR RUNNING. ECH SAYS NEW COMPUTER BOARD IS NEEDED IS THIS TRUE?
I was having the same problem .What I found was the coils were dirty and needed to be clean also the overload relay switch and the capacitor were bad.The overload relay and capacitor are next to the compressor. Replace them and you should be cool again.
Mar 05, 2010 | KitchenAid Architect KBFA20ERSS Stainless...
I have an Amana bottom freezer frigerator. The
Possibly a bad relay/overload or shorted run capacitor.If it was built between 2002 and 2005 it may be a bad compressor in which case you would want to check the warranty for possible coverage.
 the relay/overload and run capacitor plug right into the compressor on the left hand side.
 IF it isn't under warranty and the Oem part won't get it going pick up a 3in1 hard start for it they are easy to install and will get it working for you.
Sep 05, 2009 | Amana SXD524VW Side by Side Refrigerator
Freezer and frigerator stopped cooling all of a sudden. Whirlpool
hi..you either have a bad overload/relay on the compressor
or the compressor itself is bad,try replacing the overload/relay
first and if that does not repair the problem then replace the
compressor.
check it out..
thank you..
kindly rate my response..
Jul 20, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Jan 16, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore model 525321 overheat problem
hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Jun 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MZD2766GES Side by Side Refrigerator Logo
260 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
