Question about Denon Audio Players & Recorders
Hello: I have been using a Denon PMA-530 amplifier for almost 30 years, and a Toshiba SD-5700 DVD player with HDCD circuitry for about 6 years to play my CDs. I find the HDCD circuitry much superior to even newer DVD players at reproducing stereo sound with natural presence and lacking the coarseness usual to regular CD players. My Denon amplifier recently died, and I have been trying a Harmon Kardon AVR1600 receiver as a stereo amplifier. The sound quality is good using the digital output of the DVD player, but the music lacks the punch and presence of the analog setup I have used for years. I assume it has something to do with the digital to analog conversion in the new amplifier and maybe is not as good as the HDCD circuitry. Any ideas on how I can get back the old quality? I could go to an all analog amp, but my Toshiba will eventually fail and I may have a hard time finding an analog player in the future. Thanks. Bill
  • 44 Answers
SOURCE: denon 3802
m8 think thers hardware problem with it.or it could simply b that wen you pushin the amp hard then some other buttons are gettin pressed at the same time on the bord. couldnt say for sure without taking a look you could send it to these guys an they should do it pritty quick and cheap. http://www.mobilephoneservicecentre.co.uk/
Posted on Jul 03, 2007
SOURCE: Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Posted on Jan 20, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: No sound using digital coaxial connections
Couple of possibilities:
Press Audio Select on front of unit until "Analog" changes to "coax/opt"
or
When you select the component connected to the MULTI CH INPUT jacks as the input source (see page 38), this unit automatically
turns off the digital sound field processor, and you cannot select sound field programs.
Posted on May 16, 2008
DickCanFixIt
  • 948 Answers
SOURCE: DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Posted on Dec 30, 2008
SOURCE: Harmon Kardon unlock error
I have the same problem. All of a sudden no sound through my TV connection (but through the DVD connection the sound was still working). I changed the connection from video 1 to video 2 and got the sound back. It is not a real solution, but a practical one :-)
Posted on Feb 01, 2009
Denon pma 355uk Amplifier manual required?
Try Googling (denon)(pma 355uk)(manual) without parens.
Jul 15, 2017 | Audio Players & Recorders
Denon pma 250SE phono problem
Denon PMA 250SE does not have a RIAA phono preamp.
for some info about these preamp and details here;
Phonopreamps.com Home Page
Note: Choose a better quality regulated power supply,
for these preamps.
Although an updated turntable with USB can be used
without the need of such RIAA phono preamp.
Jul 26, 2012 | Denon Audio Players & Recorders
Denon PMA 700 AE maximum phono input signal
Why? Are you contemplating connection of something OTHER THAN A PHONO CARTRIDGE to it?
Be advised, only a phono cartridge should be connected to a Phono input. There's more going on behind it than just voltage step-up.
Mar 07, 2010 | Audio Players & Recorders
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
Operating Instructions, Denon PMA-535R/PMA-735R
Hi there
You can download one from here Select the FREE download button and you will get a PDF copy of the manual. Let me know if you have any problems getting it. Cheers
regards robotek
Jan 09, 2010 | Audio Players & Recorders
Toshiba DVD player doesn't retract or load media. DVD carrier is stuck in the out position
There is a rubber band on the motor that opens the tray out to load the disc, somehow that must of slip off the motor. Or the motor itself went bad.
Oct 11, 2009 | Toshiba SD-5700 DVD Player
Hi, I have a Denon PMA320. I would like to connect it to a Hitachi 32LD6200 TV. How do I get the sound from the TV through the amp please? Many thanks, RichT
If the TV has audio out jacks then you can connect them via a lead to the amp. If not the you can use a scart socket. You can get a scart plug with audio and video RCA jacks on the other end of it and connect that to the amp. If the TV has only one scart and you are using it for a video or DVD device, get a scart adapter with more than one socket.
Jun 28, 2009 | Denon PMA-100M Amplifier
Radio preset Denon UDRA-f10 doesn't save
1) tune in to a radiostation
2) press the Memory button
3) select a preset number for 5 Second
4 Skip "press Memory again"
Feb 04, 2009 | Denon PMA-100M Amplifier
346 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
