Question about Saeco Odea Go Espresso Maker - Gray/ Silver
I have an Odea Go. The Descale and Dreg Drawer lights were flashing this AM and the paddle on the brew group was rotated down and interfering with removal of the dreg drawer. We turned it off and one until the paddle finally went bacj into postition and the green light came on but now the coffee is weak and the "pucks" are really wet.
    President:
  • 239 Answers
Try here http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
and here
http://www.fixya.com/support/t4400256-descaled_saeco_odea_go_but_still_doesnt
I am not an expert in this area however I did find a couple of articles.
All the best
Jim
Posted on Oct 11, 2010
Right red light is blinking all the time
Alarm LED:
• Permanently on (one or more causes): No coffee left, water tank is empty, empty the residual water
tray is full (in this case the dreg drawer also has to be emptied to prevent problems).
• Flashing slowly (one or more causes): Brewing unit is missing, dreg drawer has not been inserted,
coffee container cover has not been inserted, service door is open, rotary knob for opening the hot
water / steam is not in the right position.
• Flashing rapidly:Ventilate the water system
Nov 09, 2014 | Saeco Odea-Giro Espresso Machine
Cannot get the brewer component out of the machine to clean out the dreg tray in the Coffee machine - instruction manual is very unclear and poorly translated.
The brew group could be out of alignment. Perhaps try turning the machine on, then close the service door. The brew group should realign automatically, allowing you to then remove the dreg drawer (tray).
Try removing the brew group after the drawer is out of the way.
May 11, 2011 | Vacuums
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
How can i reset de saeco odea giro plus ? I can not place the central unit because the axes or spindle is not in the right position.
Turn off the machine. Open the side panel, remove the dreg tray, remove the dreg box and remove the brew group. reinsert the dreg box without the tray. Using a flat head screw driver insert lightly into the slot where the brew group sensor is until you hear a click. Hold the screw driver in place while closing the side door and turning it on. The head will re-align. Now open the side panel, remove the box and reassemble. Leave the machine off for an hour and turn back on. That should reset it.
Jan 10, 2010 | Saeco Odea Giro Plus Coffee Maker
Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Dec 10, 2009 | Saeco Talea Giro Espresso Machine
Thw lights are flashing in an alternating style and I cannot get them to stop. I have cleaned and lubricated the brew group, turned the machine off, etc -- NOTHING is working
It wants you to descale..... look in the user manual for instructions how. When you have done it hold down the steam button for 10 secs to reset the descale warning lamp.
Andrew
Oct 18, 2009 | Saeco Odea Go
SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Odea Go Espresso Maker - Gray/ Silver Logo
116 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
