Question about Microwave Ovens
Ge gsh25kgmb ice maker and ice dispenser working fine, but all of a sudden water dispenser is doing nothing. please help thanks
guru_fixya
  • 944 Answers
SOURCE: Hi, I have a Kenmore
This problem is caused due to these reasons.
1)Bad water inlet valve,make sure the water reservoir in the refrigerator is not frozen and check if 120 VAC is coming to the water valve solenoid while the water dispenser calls for water.
2)You have two separate solenoid valves. One feeds the ice maker the other one feeds your water dispenser. You can shut the water off, take the hose off and clean the strainer. or you can check for voltage going into the solenoid, press for water and check power going into the solenoid that is feeding your water dispenser.
3)Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does try a hair dryer blowing where the water line is at the dispenser for a few minutes.Water pipe in the freezer door was frozen then this will cause this issue.
4)If the refrigerator water filter,remove it.Make sure the sediment filter is not blocked.
5)Clean saddle valve,shut off valve if it is frozen melt the blocks of ice.
6)See if water is getting to the door. You have to track the water line and disconnect it from the bottom of the door. Then water that might come and hit the paddle to call for water. If you do get water then you have an issue with the tubing in the door. If still no water trace your lines back into the fridge compartment and make sure it is not kinked or even frozen.
7)Switch off your refrigerator for 8 hours or more and let the fridge get warm and melt all the frozen ice.Then switch it on and check.
8) If still the problem persist dispenser switch is defective
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 05, 2010
kel1guy2002
  • 3740 Answers
SOURCE: not making ice. water is
Hia and wl;ecome to FixYa, I am Kelly.
We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
Here is a web link that will help most people troubleshoot ice maker problems:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link above is pretty good.
There is a 48 page job aid also for whirlpool in door ice that is also a big help:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
This should help you find out why it is not making ice.
Thanks for choosing FixYa,
Kelly
Posted on Oct 26, 2010
  • 5370 Answers
SOURCE: my amana arse667bs digital display
The display panel has wires on its mini circuit.Check out the wires,if they are loose then re-solder the wires and recheck. The display panel has to be removed out of the unit.Its fitted by screws,you will have to slide it out.Just check the wires,if the display panel itself looks burnt or short inside on the circuit,then it has to be replaced.--------- You can get required parts from www.repairclinic.com or from searspartsdirect online site. ---------- This will help.Thanks .Helpmech.
Posted on Dec 26, 2010
SOURCE: i have an electrolux side
I am having this exact same problem. Any answers??????
Posted on Jan 05, 2011
  • 5 Answers
SOURCE: Have Kenmore sid-by-side refrigerator: 7909621940B
We also have a kenmore side by side refrig and had the same problem,,,
FIRST, CHECK THE CONNECTION BETWEEN NEW FILTER AND ATTACHMENT POINT,,
IF THE RUBBER GASKET CAME LOSE DURING THE CHANGE, IT MAY BLOCK THE PATHWAY FOR WATER TO FLOW
NEXT, CHECK THE WATER/ICECUBES/CRUSH LEVER SWITCH TO MAKE SURE IT IS NOT PART WAY BETWEEN ONE OF THE SETTINGS,
NEXT,CHECK TO SEE IF YOUR UNIT HAS A RESET BUTTON,
THE RESET BUTTON IS USUALLY IMMEDIATELY INSIDE THE OPENING WHERE THE WATER/ICE DISPENSES AND UP, YOU WOULD NEED TO PLACE YOUR FINGER RIGHT DIRECTLY UP BEHIND THE FRONT PLASTIC COVER, AND IT'S GOING TO BE A VERY SMALL BUTTON, I AM NOT SURE WHICH SIDE ON YOUR UNIT R OR L, BUT DIRECTLY UP IN THE CORNER,,
I HOPE ONE OF THESE HELPS !! angi
Posted on Feb 06, 2011
Water does not come through the water pump at the bottom of the refrg
If water is getting to the water valve then either the valve is not getting power from the dispenser and ice maker or the valve isn't working and needs to be replaced.
Aug 26, 2011 | Microwave Ovens
Hi, I have a amana fridge with freezer on the bottom. It has an ice maker and water dispenser. The big problem is a buzzing noise comming from the fridge, it start aprox every 16 min and buzzes for 10...
The buzzing you hear is the water valve trying to run water to the icemaker. If there is no water going to the icemaker it will be going into cycles one after another. And when it does it adds heat into the freezer. Turn the ice maker off and see if the freezer gets colder.
May 20, 2011 | Microwave Ovens
Have Kenmore sid-by-side refrigerator: 7909621940B - Just changed water filter. Now, no water or ice dispenses. Ice maker is making ice - filled the bin over a few days. But, when I push to dispense...
Feb 05, 2011 | Microwave Ovens
Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
Kelly
Oct 26, 2010 | Microwave Ovens
Here we go, I have a GE side by side about 6 years old... Started with the icemaker not dispensing ice consistently... then the ice stopped all together (even though the bin was full and not froze solid)....
The clicking you are hearing is the relay unit. Now it is for sure that the compressor is not working as the relay keep s tripping off.
So first of all to clear this doubt, let us checck the relay unit which is clicking. remove and check. most of the time the relays need to be replaced as a poor contact will not deliver good voltage to the compressor and it will shut off. So check this out.
One the compressor works and you notice there is cooling the sytem seems ok except that you must check if the thermostat, the auto defrost cut off timer works.
If after the compressor works the cooling is not good then you can decide on a replacement than to spend for expensive repairs
Sep 12, 2010 | Microwave Ovens
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
