Question about Craftsman Garden
Replacing the dual-line on the 15" Electric trimmer - Do you run the line through the slot on the casing before the outlet hole?
    President:
  • Craftsman Master
  • 1,545 Answers
The slots on the string spool are there just to hold the line in place so it doesn't unwind while you are putting the string head back together. You have the strings sticking up, you lower the casing with the eyelet holes down, feed the ends of the strings sticking up through the eyes and then yank them free of the slots so they can automatically feed. So yes, line goes from spool hub to spool slots to casing outlet holes and don't forget to pull it free of the slots.
Posted on Oct 16, 2010
Replacing the cutting string
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, 11
Feb 11, 2012 | Garden
Why is line feeding out too fast on 503a
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 29, 2012 | Garden
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
How to replace trimmer line ?
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Toro Electric Trimmer
Ryobi 30cc trimmer setting the timing belt
I set the crank pulley with the slot in the mag (shiny) section pointing up toward the camshaft (appeared to be top-dead-center looking thru SP hole). Set the deep hole in the cam pulley down to align with the crank slot. Slipped on the belt and surprise-surprise it fired right off. May need a bump one tooth either way, but too late to run it much tonight.
Aug 04, 2009 | Ryobi 15" Electric Factory Reconditioned...
Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Describe string replacement on ryobi trimer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
How do load a dual line trimmer for a husqvara 223L
Cut two separate pieces of string, about 7 ft. each. Stick the end of the lie in the hole on the inside of spool. Wind clockwise onto spool, putting the line that is closest to the ground on first. Once you have winded this piece on, lock the last 4 inches of line through the slits on spool. Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece. Put the spool on the trimmer, feeding the end of lines through either hole on trimmer. Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 10, 2009 | Husqvarna 28cc Gas Line Trimmer
RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
Oct 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Jul 06, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
173 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
