Question about Dryers
Any thought on where I can get a replacement for a GE Rapid Start Class P Electronic Ballast? Description: FEH382D/6/120
2 Suggested Answers
SOURCE: I talk about BRINKS TIMER
S?lo s? una sola lengua. Puedo usar traductor Google para ayudar.
http://translate.google.com/
CFL light bulb has electronic ballast.
Las bombillas CFL tienen balasto electr?nico
46-1022 will not work for CFL, or motors.
46-1022 no funciona para CFL, o motores.
http://respectmyplanet.org/helpthecause/wp-content/uploads/2011/02/cfl2.jpg
Older fluorescent light fixtures have rapid start ballast.
Antiguo luces flourscent han lastre inicio r?pido
http://images.bizrate.com/resize?sq=220&uid=1793142337
Nuevas luces flourscent han lastre inicio r?pido
Electronic ballast makes less noise, use less energy, cause less electrical interference, and the ballast lasts longer.
Balasto electr?nico hace menos ruido, consumen menos energ?a, menos causar interferencia el?ctrica, y el lastre de tiempo m?s prolongado.
Take cover off fluorescent light and read what is printed on ballast.
A cubierto de la luz fluorescente y leer lo que est? impreso en lastre.
Posted on Jul 31, 2011
My 2005 GMc envoy stopped when I stopped at stop sign the service brake system warning keeps coming on when push brake pedal. Gear shifter won't move out of park and it will not start.
Hello Kammy ,you have electronic problems ! Your best bet would have it towed to a qualified repair shop .
SERVICE BRAKE SYSTEM
Refer to Brake Warning System Description and Operation !
The instrument panel cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
• The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination.
• The electronic brake control module (EBCM) detects a low brake fluid condition. The IPC receives a class 2 message from the EBCM requesting illumination.
• The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP). The IPC receives a class 2 message from the EBCM requesting illumination.
• The IPC performs the bulb check at the start of each ignition cycle. The brake warning indicator illuminates for approximately 3 seconds before turning OFF.
• The IPC detects a loss of class 2 communications with the BCM or with the EBCM.
When there are electronic problems the computers will not allow the vehicle to start , hooking up a factory or professional scan tool to see what the problem is is the first place to start .
Apr 14, 2017 | 2005 GMC Envoy
Maintenance
Generally you can't run ECO or ALTO tubes (less mercury) in fixtures meant for regular Rapid Start/ Preheat tubes. Other than that Old tubes near end of life sometimes do that.
Feb 24, 2014 | Televison & Video
My yard light, I think its a mercury vapor light? will go off randomly at night and come back on after about 30 seconds continuously. Any suggestions?
Check whether it is self ballast, if it is self-ballasted, so the ballast is integrated with bulb itself, so you can replace it with a new bulb, it can be self-ballasted mercury vapor bulb or regular energy saving bulb., if it is mercury bulb need work with ballast, from your description, the capacitor should be replaced, which is a little bit complicated, you should check it with electrician, or you can do it carefully after you read some documents.
Safety Tips: Turn power off at any time before you start to repair any electric appliance or lighting equipment.
The following is some reference for mercury bulbs and its associcated ballast.
http://www.bulbspro.com/lightbulbs/hid/mercury-vapor.html
Good Luck
Nov 03, 2013 | Home
TV blue light comes on, then the red light blinks two times, on the 3rd blink, it goes into rapid blinking. I replaced the lamp and it worked for a week, but then the same issue. I put the old lamp back...
some units require a lamp counter reset.the ballast usually starts at extreme output and at certain hour interval the ballast would start to decrease voltage as the bulb ages.to reset on some models can be reset using the remote
Aug 12, 2013 | JVC HD-61Z786 61" Rear Projection HDTV
Electronic ballast for hbf1205P-263
http://www.ballastshop.com/veb-82223-with-socket-connector.html
Jan 03, 2012 | Hampton Bay Dryers
Brinks timer Model 46-1022 has an intermittent flicker with CLF and LED bulbs. (I have not tried recently with incandescent bulbs)
46-1022 is rated incandescent and rapid-start fluorescent ballast.
CLF has electronic ballast and not rapid start.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
For single-pole and 3-way timer that works with CFL and halogen, use Aube
http://waterheatertimer.org/Aube-timers.html
Aug 15, 2011 | Garden
I talk about BRINKS TIMER 7 DAY 46-1022 What type of flourescent light should be use. The manual say "Rapid start flourescent lighting, (the type with no electronic ballast)" Would you say...
Jul 31, 2011 | Hardware & Accessories
Having probs with the flourescent fixtures, do they have ballasts (starters)? Beverage Air MT66
no most newer units are either rapid-start or electronic ballast operated, check for moisture and corrosion on lamp pins
Oct 24, 2009 | Beverage-Air MT66
Panasonic TV pt-50lc13 bulb replacement
Take the bulb out, there should be a access panel in the front, power the set on,(be sure to have the lamp door closed) if you hear a rapid ticking noise from the set, the Ballast is trying to fire the lamp, this is a good indication that the set is functional but the lamp needs to be replaced. If not, the ballast is not getting the voltage needed to start the lamp.
Sep 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Dryers Logo
312 people viewed this question
Top Dryers Experts
