Question about Jenn-Air 24 in. DW961 Built-in Dishwasher
Jenn Air DW961UQW Partially Fills, Drains and Done
My dishwasher partially fills and then drains the water. Not much happens after that. What could be the problem?
Is there a diagram of how to replace pump in the jenn=air dishwasher model dw961uqw?? If so is there aweb site I could look at? Thanks Ida Vogegelgsang
Posted on Feb 08, 2009
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
Does not fill with water
The water level detection is done via a small plastic pipe from the bottom of the machine that fills with water and causes the air pressure in the pipe to activate a micro switch in the water level detecter. The pipe can be disconnected at the bottom and gently blow into the pipe. If you listern carefully you can hear the micro switch click. The pipe must not be blocked and in some cases the switch contacts could be burnt. The water level is factory set but can be adjusted on the water sensor. Replace if necessary.
Apr 24, 2010 | Kenmore 24 in. 16049 Built-in Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Fills with water and drains will not run to wash dishes
The main water pump is not working. A repair will be pricey. it may be best to get a new dishwasher
Apr 21, 2009 | Dishwashers
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
Standing water in dishwasher
Check your "air gap". This is the device that sticks above the countertop and prevents any water backup from getting into your dishwasher. The problem may well be a partially clogged air gap.
Remove the decorative cover and there should be a plastic dome that can be removed. Firmly grip the plastic dome and move from side to side while pulling up. Once you get the dome off you will be able to see if it is clogged. This can be done without removing the drain hose from the bottom of the air gap. This solved my problem which was the dishwasher not completely pumping all the water out. After cleaning the air gap it drains properly.
Mar 12, 2009 | Bosch SHV4803 Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
173 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
