Question about Canon Office Equipment & Supplies
I have a Canon Lotte Lc-8035 machine and i usually have print problem and paper jam? What's its solution?
  • 3 Answers
SOURCE: PRINTING PROBLEM WITH CANON IP1880
please try
http://canon-resetter.blogspot.com
http://epsonresetter.blogspot.com
Posted on Mar 19, 2008
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
iservice
  • 318 Answers
SOURCE: Jammed Paper - Canon PC860
You are almont there .There is also 2 clips that release the presure on the sides of the fuser to release the presure on the roller and remove the paper.
Posted on Jan 23, 2009
SOURCE: OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I've just cured the same issue.
Inspired by MCS-IT, I fed a sheet of paper into the paper path (printer over the edge of the desk) popped open the front cover and manually drew the paper through by turning the cog wheels. Voi-la (sorry French spelling not a strong point) a small piece of ripped paper was forced out!
Posted on Feb 21, 2009
copiersplusw
  • 136 Answers
SOURCE: Copy Machine Canon GP335
OK i have seen this problem, whats is going on is ur paper feed tires are slipping and needs replacinGg, THIS IS GREAT NEWS FOR THE SERVICE TECH,
call ur indepentant serivce tech or if your in Ct we can help your feed tires need replacing and this could help your jam errors.
Posted on Mar 08, 2009
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Puts a black ink line down the back side of the paper when printing fades after it prints about 5 sheets
This is usually a piece of paper stuck in the machine after a paper has gotten jammed. look carefully around the area where the printing is done and near the exit slot.
Mar 21, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Paper Jam
you dont you might have a dirty or bad paper sensor there is also a chance the paper might be in the fusing area (where its hot) if u use a flashlight and look in that area you might see the paper at that point it needs to be taken apart
Aug 28, 2009 | Canon LC-3175 Laser Fax
I have Paper Jam Display on my Canon Super G3 Fax phone L80 FaxScreen.
There is most likely a piece of trapped paper where you cannot see it and it is covering a jam sensor. Try to cheat the machine by turning it off and remove all the printing paper. When you turn it on look down where you see the paper normally feeds and see if you can see any rollers turning. Then, try to take a sheet of paper and feed it through were the printing paper usually goes. Open up the cover where the cartridg goes as well and you may see the trapped paper move when you feed through your piece of paper. Remove the cartridge if necessary to get a good look and see if paper is trapped near.
Jul 08, 2009 | Canon FAXPHONE L80 Laser
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
Oct 10, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Have a paper jam near the exit
THe idea is to keep you from doing that.  If the paper is jamming inside the machine, it probably needs a new fuser unit.
Sep 24, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
old marine
old marine
