Question about Acer Aspire 3610 Notebook
My wireless switch doesn't enable - Acer Aspire 3610 Notebook
    Sergeant:
  • 226 Answers
Make? Model? B - G - N? Is it plugged in? Does the power supply work? Measure the voltage across the inner conductor and outer conductor of the power supply output. Does it match the output specified on the label? Did it ever work with your other equipment?
tom
Posted on Oct 11, 2010
I have an acer extensa 4630z. i cannot turn on the wireless capability. is there any alternative way on how to turn it on except for its switch. the switch doesn't work anymore. thanks.
Try this.
Go to Bios when the laptop boots (hit F2 or F8 at the startup ), and see for Wireless menu, you can modify two important settings. Make sure the wi-fi and bluetooth (if you want) are both Enabled. Then a few entries down there is a "Wireless Switch" category. Change this setting to "None." Then, go to the "Wi-Fi Catcher" category, and change that to "Off."
This will cause the laptop to completely ignore the hardware switch on the side, and force the card to stay on at all times. Now it doesn't matter if your switch is broken.
Meanwhile, if you never NEED to turn off your wireless card, you can just right click on it and disable it from within your network adapter settings.
Aug 14, 2012 | Acer Computers & Internet
Sylvania net book doesn't see available wireless
If it's not seeing wifi networks, more than likely, there is something wrong with the adapter. Try these steps:
1.) Look for a WIFI switch on the side or front of your laptop and make sure it is set to the ON position. 2.) Check Device Manager to make sure the driver is installed and working. If it's not, uninstall and reinstall. 3.) Go into Network Connections and make sure the Wireless Connection is set to Enable. 4.) If none of that works, perform a System Restore to a time when everything was working. 5.) If this doesn't work, you need a WIFI adapter replacement.
I hope this is helpful and thanks for using Fixya!
Sep 23, 2011 | Computers & Internet
I can't turn on my wireless LAN. There is a button at the top of the keyboard of my Acer Aspire 4520 but when I press it, it says "wireless LAN disabled". I have tried everything to turn it...
hi, plz type " ncpa.cpl " in run command, it'll shows the network connections. if the wireless (WI-FI) driver is updated, it'll shows in that screen. just move the cursor to wi-fi connection and right click it. it might have been disabled. if it is disabled plz enable it and switch it on ur WI-FI switch...
thanks & regards Anas K A
Jun 01, 2011 | Acer Aspire 4520-5582 Notebook
How do I switch on my SONY VIAO Laptop to accept wireless internet, which I know is working fine
Depending on the model you own, most Sony Viao laptops have a small slide switch along the front edge.
May 27, 2011 | Computers & Internet
How to activate wifi in janab
There will one of two different types of switches or buttons to enable the wireless networking feature on your notebook.
Button on the front of the notebook:
  1. Locate the wireless networking button on the front of the notebook.
  2. Press the button to either enable or dislable the wireless networking
  3. Once the wireless networking feature is enabled the button will light up amber.
Switch on the front of the notebook:
  2. Slide the switch to the right to enable or disable the wireless networking feature
    Note: The switch will reset back to the left after switched to the right. This is normal and does not indicate the the wireless feature has been disabled.
Nov 30, 2010 | Acer Aspire 4720 Notebook
Can't enable Dell Wireless 1390 WLAN Mini-Card
I had the exact same problem and went through the same steps that he did. It was only when I searched for a physical wireless switch (on the left side of my Dell D630) that the problem was solved. I didn't even know it was there and must have inadvertently knocked into the off position.
Dec 12, 2009 | Dell Inspiron 6400 Notebook
The wireless wan in my aspire 6930 no longer function, what can i do to fix it?
Make sure the drivers for the wireless card are installed and also that the wireless switch is turned on.
Those are the two main things to check, are you able to look for networks or is the wireless completely unavailable?
If its completely unavailable it might be disabled or the drivers are missing. to check this, right click on your my computer or computer, which you will find from either your desktop or from start menu.
Select Manage.
On the computer management window on the left side click on device manager, look for any devices with a RED X or a yellow ? mark.
Also look under the network adapters, what do you see there?
Sep 11, 2009 | Acer Aspire 6930-6771 Laptop
I had wireless for some reason it has been disabled how do i enable the wireless adaptor
To enable wireless adaptor, check for switch at sides of the laptop. There is a wireless switch which enables or disables wireless.
On some laptops, there is a function key (Fn), press Fn and F7(or F5) at the same time to enable it
Jul 27, 2009 | Acer (BCM94318MPG) Wireless Adapter
When trying to enable my Wireless,I am told that I have to use my hardware switch to enable Wireless.The hardware button ,is on the side of my laptops keyboard....it does not work I have tried enabling it...
ok..enable the wireless..three switches so to speak..
physical switch on side..check
network setting in control panel switch..check.
actual wireless card switch ...check..
get all three..you should be there..
Oct 08, 2008 | Computers & Internet
Acer Aspire 3610 Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
