Question about LG Bottom Freezer Refrigerator w/ Swing Freezer Door 22 Cu. Ft. - LRBN22514
My freezer is cold but not freezing the refrigerater is cold also but not as cold as normal.what could be going on cleaned coils already.
  • LG Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 12, 2010
Crosley Refrigerater Freezer not running, only fan bows. Not cooling.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 09, 2011 | Crosley Refrigerators
The freezer and refrigerater is not getting cold. PLEASE HELP
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 17, 2011 | Refrigerators
My Frigidaire Mod. # FRS6R5ESB0 P/N 218888702 side by side the freezer is cold close to freeze but not freezing, what can I doo, I already clean the coil condenser and the entire back compartment. Thank...
Refrigerator
heatman101
Dec 25, 2010 | Frigidaire FRS3R5EMB Side by Side...
Hi, my freezer is super cold, and my refrigerator side is freezing my milk, my water ,what may be the problem? I have already cleaned the coil and the compressor. Thanks
well the coil being clean will just allow the compressor to function properly. You have a cold control problem. Too much air getting into the fridge. adjust the settings. Turn the settings to the fridge side warmer and the freezer side colder... then allow 24 hours to adjust... if still too cold then have a tech come out and service it it probably has mechanical problems
Sep 17, 2009 | Roper Refrigerators
What do I do? My refrigerator is warm but my freezer is cold.
you may have ice buildup in the evaporator ... i would take everything out (put food in insulated picnic baskets or someone elses refrigerater) .. then turn it off or unplug it over night with all doors open ... put down towels to catch any melting ice water .. empty ice tray ... the next day turn it back on and see if it doesnt cool properly ..it will take a few hours to stabilize ..
the problem likely was caused by a door being a little open for a long time ... that lets lots of moisture in which may freeze and accumulate on the evaporator .. the system cant recover from that unless you completely defrost it as above ... you might want to clean underneath it while you have it out of service .. vacuum/clean the coils and fan
Aug 05, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
My freezer and refrigerater will not get cold
u would have a leak in your sealed system if the fan and compressor are working and still not cold very expensive to fix
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
Side X side TFX20JA refrigerator not freezing or maintaining cold
Thank you for your help!! I was able to repair my refrigerater thanks to someone who had previously had the sam problem and was given three things to check. The problem was the heater in the freezer was burn out.
Jan 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana fridge
is the freezer cold. the freezer is acualy the only refrigeratted compartment . it has the evap coil in the rear wall and a fan to cerculate the air . a potion of the air is let into the food compartment . most comonly the freezer defrost system can be the fault. so i would requier answers to the first question. is the freezer compartment working. hope this helped
Oct 19, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
LG Bottom Freezer Refrigerator w/ Swing Freezer Door 22 Cu. Ft. - LRBN22514 Logo
119 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
