I once booted up the notebook (N90S) and forgot to plug in a usb, so i shut it off by pressing the on/off button again (it was booting up at that time). Once it turned off, i wanted to boot it up again but it didn't. The cooler makes no sound, and only the lights on the side glow up. On the top it shows some lights showing up, lockers or something, its like its locked or something and im curious, if someone knows how to unlock or knows another solution?? PLEASE HELP ME
    Sergeant:
  • 226 Answers
You may have put it into hibernate or sleep mode. Sometimes a key press or mouse movement will wake them up. Other times you have to resort to the straightened paper clip pressing on the hidden reset button. Get your manual out and see if there is a manual reset button you can use to reset the machine. If not, remove the battery if you can and let the machine 'forget' what it was doing. Wait 10-15 minutes before re-installing the battery pack and trying to start it up again.
tom
Posted on Oct 11, 2010
I need help in forgot my password on my icraig notebook cip285,
First, on boot press F8 on your netbook and choose the safe mode. You will be then redirected through the administrator of that account on that log on screen. Shut off your computer and turn it on again and continue to click on F8 on your keyboard. You will be directed to advance boot option menu. You need to select safe mode. Select again administrator this time it won't require you to encode password. Once you logged in to your computer. You need to go to control panel > user accounts. Click on the user account and put on your new password.
Jul 11, 2016 | Computers & Internet
Password for my macboor air
Sadly enough there's no other way to get back into your installation. If you need to backup your data, either boot into windows with the bootcamp drivers installed or take out your hard drive and plug it into a pc. Once you have a backup completely shut down your macbook and plug it in. Press and hold CMD+R and turn the Macbook on, it should now boot into recovery, where you can format and reinstall OS X.
Mar 18, 2014 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
Boot hp pavillon zd8000 with usb not possible?
Boot hp pavillon zd8000 with usb is possible.simply plug the USB flash drive with iso and reboot, then press F10 navigeyt Boot Order Mark hard drive, hit enter, Highlight your usb and press F6 so usb was on top of the press F10
May 15, 2012 | HP Pavilion zd8000 Notebook
My little sisters dell inspiron mini just got the Unmountable boot volume message. I've looked online but most of the options require a cd which is of course not helpful when the mini doesn't have...
The best option is, look around for external cd-rom with usb connection, and reformat the laptop.You need to go into the bios and change the boot order to make your usb cd-rom to first in the boot list. Once the usb cd-rom is plugged into used port, with operation system cd in it, on your laptop..press F2..go into the bios, to the boot order make your usb cd-rom on top boot list,,then save changes to exit the bios. Once again the system reboots..with message PRESS ANY KEY TO BOOT FROM CD ROM.. so just simple steps to follow..its not going to be expensive..good luck
Sep 17, 2011 | Dell Inspiron Mini 10 Notebook
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
0701 usb over current on hc/port error
I had the same problem on a toshiba satellite u400.
Usb over current on port ... blabla..
Please press F1 to resume or F12 to install.
F1 just ended up in a screen asking to press F2 or F12 which did nothing.
F12 did nothing.
Rebooting the pc ended in a black screen with a flickering HD symbol.
To be able to boot again on the BIOS I had to remove the battery and disconnect the plug.
Once It restarted booting on the error USB over current.
Si I took a USB mouse and tried to boot with the mouse plugged in on port , then another ... at the third port the PC booted normally with no error :)
Don't have any idea why it became faulty but it's now solved for me.
Mar 12, 2009 | Toshiba Satellite A135-S4527 Notebook
HP 7410 shuts down
how long it takes before it shuts down,
answer quickly or else i'll forget helping you.
Mar 06, 2009 | Acer TravelMate 290 Notebook
Usb power issues
Some systems will try to boot up on a usb device such as an IPod or a external hard drive.
It should be unplugged to get it to boot properly.
Oct 31, 2008 | HP Compaq Business d530 Ultra-Slim PC...
No post/blank screen
Do you have your Windows XP CD? Boot from that CD and at the prompt, press r for repair.
select 1 for windows installation and at the prompt type the follwing and press enter:
chkdsk /r
once complete (will take some time), reboot and you should be back in action
May 02, 2008 | Compaq NX6110 TFT XGA Notebook
Acer aspire 5610z
find and look the simos battery detach and place
back again.
Jan 05, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
