Question about Nintendo Wii Console
Remote will not operate: says communications with the remote cannot be found
  • 56 Answers
There are series of problem in nintendo wii which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the nitendo wii repair guide that will help you a lot....all the best...
Click Here
Posted on Oct 11, 2010
Need to change fuse on remote keyless entry but don't where it's located on fuse box on 2004 explorer
Do any doors lock/unlock with remote keyless entry ?
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter battery.
  • Remote transmitter.
  • Remote transmitter programming.
  • Aftermarket system.
  • High power devices.
  • TV/radio transmission towers.
  • Vehicle security module.
  • Go To Pinpoint Test C .
Pinpoint Test C: The Doors Do Not Lock/Unlock Using The Remote Transmitter
Normal Operation
Remote locking and unlocking of the doors is accomplished by the vehicle security module receiving a command message from the remote transmitter. The vehicle security module processes the command and sends a signal directly to the door lock actuators.
All remote transmitters must be present to begin diagnosis of the remote keyless entry (RKE) system.
Aftermarket or dealer-installed systems may adversely effect the RKE system operation. These systems should be disconnected before diagnosing any RKE concerns.
Visual Inspection Chart Mechanical Electrical
  • Latches
  • Battery junction box (BJB) fuse(s):
    • 2 (30A)
    • 16 (15A)
    • 22 (20A)
    • 29 (60A)
  • Central junction box (CJB) fuse 20 (5A)
  • Circuitry
  • Relays
  • Keyless entry keypad
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
  • Check that the program card is correctly installed.
  • Check the connections to the vehicle.
  • Check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • SCP+, SCP- OR UBP circuits fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for vehicle security module, refer to Section 418-00 .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the vehicle security module.
  1. If the DTCs retrieved are related to the concern, go to the Vehicle Security Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If DTCs are retrieved that are not found in the following Vehicle Security Module Diagnostic Trouble Code (DTC) Index, refer to the Master Vehicle Security Module Diagnostic Trouble Code (DTC) Index in Section 418-00 .
  1. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Nov 18, 2015 | Cars & Trucks
The AV button from my remote isn't working at all.I bought a new one but the catalog doesnt have Cosmo Communication TV brand.I would like to know what code I need to put so the AV can appear on the TV.
Read the manual that came with the remote. Most of the time you can find your device when you put the remote in a "search" mode and then you have to press a button several times, till the TV switches off. Then press anything again and your remote should be set up. Something like that should be on the remote for setup. When the TV responds, check all buttons, to see if any of the keys switches the AV.
Feb 24, 2015 | Televison & Video
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
Laptop displays operating system not found
No communications between the hard drive and main board. Try reattaching if possible. Then verify the drive is being picked by BIOS.
May 24, 2013 | Lenovo Computers & Internet
DVD recorder DMR-E20 will not communicate with remote
Have the remote tested, it can be done easily without the unit, also most digital cameras in a very very dark room can be used--point remote at camera (with it on) and press buttons, you should see a tiny flash on the display screen of the camera.
If the remote tests good the remote receiver in the unit it operates may be bad.
Attached is a typical receiver, yours may not have the metal bracket and the item in the picture is actually less than 1/2 inch tall.
Dec 21, 2012 | Panasonic DMR-E20 DVD Recorder
Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
May 14, 2012 | Televison & Video
What does NGB0 mean on the activity report?
NG is shortcut for "No Good", indicating a problem. "B0" is the fault code for a communication problem, usually caused by an incompatible setting of communication mode G2 or G4 on the remote machine.
Contact the remote operator and ask he set up his machine for EECM or G3 communication mode, then retry.
Jan 06, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Need 5-digit code for universal remote on DAV-X1
There may be no code in the library of your Insight remote. You may have to try a different universal remote.
Apr 04, 2017 | Sony DAV-X1 System
My remote
Sounds like you've accidently switched the remote to operate under remote code 2 - to switch it back to operate under remote code 1 you need to hold down the "Enter" button on the remote, and while doing that press the "1" key.
Aug 16, 2007 | Panasonic DMR-E80H DVD Recorder
Nintendo Wii Console Logo
70 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
