Question about Intel D865GBF Motherboard
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never booted after that. There are total 4 slots on the board. When used the old RAM (256) system worked fine. When I placed both the old an new RAM the pc got booted but it just displayed the black screen with some contents on it in white. Is the new RAM faulty? Is there any issue with the slots? Is 1GB RAM supported on this system? Or do I need to buy 4- 256MB RAMs each for one slot and will it work?
    Guru:
  • 124 Answers
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Posted on Oct 12, 2010
I have intel 915 GLV mother board and 256mb ram, now i want to upgrade my ram to 1GB. please let me knw what kind of RAM i need to buy along with its image details.
Intel Desktop Board D915GLVG - motherboard - micro ATX - LGA775 Socket
Max Supported Memory 4 GB Supported RAM Technology DDR SDRAM Supported RAM Speed 400 MHz, 333 MHz Supported RAM (Registered or Buffered) Unbuffered RAM Features Dual channel memory architecture
Aug 10, 2011 | Intel D915GLVG Motherboard
I have a 512 mb 667mhz sdram on D102Ggc2 board.now i decided to up grade memory. Can i upgrade system memory without lose this 512 mb.
Yes you can. but make sure that you buy the exact same type of RAM stick that you have and put it in the other RAM slot so the Dual Channel feature will be active (dual channel makes data transmission/processing faster) and making your systems memory 1GB. However, your motherboard can utilize or handle up to 2GB or RAM so you can put also a 1GB RAM stick which will make your systems memory a total of 1.5GB (that will be the case if you really dont want to lose the 512MB that you currently have,
Hope this helps.
Jul 09, 2010 | Intel D102GGC2 Motherboard
What type of graphic card i can buy for my gateway 556 ge computer
First increase the ram from 512 Mb to 1Gb then purchase the 256/512 mb Graphics Card in market.
thank u sir .... Have a nice day
Apr 17, 2010 | Gateway 556GE Intel Pentium 4 630 3GHz(HT)...
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Memory channel mode
Hi shinde32, you should know that dual channel memory should be bought as a pair. Your board has two DIMM slots as you mentioned. The board can handle up to 2GB max memory, as you have mentioned. What you do not seem to know is it is required to use the same amount of memory is each slot. See the bottom of page 55 in your manual. (Do you need the manual)? Download at this link;
http://download.intel.com/support/motherboards/desktop/d102ggc2/sb/d4798502_en.pdf
There is not a bios setting where you can enable or disable memory channels. The bios configures the memory automatically. Intel has a list of memory tested & passed for the D102GGC2 Mb. You can see that list at this next link.
http://www.intel.com/technology/memory/ddr/valid/DDR2_sodimm_results.htm
Bottom line, both DIMM slots should have two 512MB DIMMS or two 1GB DIMM's. (Like this memory);
http://www.bzboyz.com/ProductDetails.asp?ProdID=18112
https://www.thefind.com/computers/info-spd-dual-channel-kit-memory
This is what your search would look like,
"1GB x 2 DDR2 dual channel 533MHz SPD memory".
The Certified "SPD" is important for Intel MB's.
Good luck shinde32!
Need more help, post here.
Thank you for using fixya.
Mike
Jan 15, 2009 | Intel D102GGC2 Motherboard
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Ram
Hi roniduncan,
Your Intel D865GBF motherboard does not support DDR2 memory.
The D865GBF motherboard does support.
DDR400, 2.5 V Dual channel and up to four 184-pin Double Data Rate (DDR) SDRAM Dual Inline Memory Module (DIMMs) connectors with gold-plated contacts.
Do not have your manual? Download from this link.
http://support.intel.com/support/motherboards/desktop/d865gbf/sb/cs-008983.htm
Please turn to Page 17 in your user manual. (Memory specs).
Inte D865GBF motherboard main web site.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=948&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Any more questions? Feel free to ask.
Mike
Apr 23, 2008 | Intel D865GBF Motherboard
Intel D865GBF Motherboard Logo
110 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
