Question about HP DeskJet 810c InkJet Printer
Cannot turn on the printer even if connections are ok ?
    Scholar:
  • 89 Answers
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Posted on Mar 16, 2011
  • lawrence Hattingh Feb 29, 2012
    if i read all the printer problems with power errors. the cords ,the wall sockets are working i am convinced that manufacturers of these printers should sort there problems out,my printer is about 3 years old but has a working time of about 10 hours. Surly they last longer than this.i will never buy a canon product again.
HP Officejet 6500 Wireless one day i come home and when i turn on my printer i get a mssg that there is a paper jam so i look and chek that everything is clear so its a flase paper jam then i resart it and...
You may have to get the printhead replaced but first:-
Was the paper jam cleared?[disconnect everything even your PC and re-connect to start afresh]
Clean the printhead by:-
  • Load a plain A4 size paper into paper tray.
  • On the printers control panel,press the setup button.
  • Select tools nad then press OK.
  • Select 'clean printhead and then press OK.
  • After the printhead cleaning,turn the printer off and then on.
Hope this helps.Thanks!
Oct 13, 2011 | HP Officejet 6500 Wireless All-in-One...
This printer is connected to 1 pc via usb and prints via the network from pc 2 and 3.it suddenly stopped printing from pc no 3 but still prints from pc 2
If the printer is printing from pc1 that means the usb port is ok. If prints from pc2 that means the network port is ok, so the problem is not in the printer but in PC3. Check connection of pc3 to the network, check the settings, check recently installed programs - especially firewall or new antivirus version. Scan for viruses - there are some blocking traffic. You can even turn the pc3 back in time using the system restore service.
Hope this helps.
Sep 13, 2011 | HP Laserjet M2727nf Multifunction Printer
The printer is offline and not connecting to the network. I have tried everything.
Does it show any error message, or it just stays there like that?
Here's where to start. On your printer/fax press "Menu." Then press 5, and click "OK." Then press 2, and click "OK." It should say "Searching SSID." Make sure you are connected to your own wifi network and that your network key is inserted right.
Then, go into your wifi router's settings and make sure the DHCP server is set and that the printer can get an apropriate IP address to connect to the network.
Are you trying to connect it directly to your computer's wifi card? or are you using the router's access point. There might be issues with that too.
Have you tried connecting it to the USB cable? Even if it can't connect to the wifi network, it should always be able to connect to the wired USB interface.
Try to troubleshoot it a little. and maybe add some additional details so that we can assist you better.
May 22, 2011 | Brother MFC255CW All-in-One InkJet Printer
Fax machine not sending documents
A) Run the fax test on the printer itself to see if it's connected properly and has an active phone line.. HP All-in-one printers still make a dial tone sound even if they aren't connected to a phone line. To run the test 1)..Press the SETUP button. Press the down arrow button until "Tools" is highlighted then pres OK. 2) Press down arrow key again and select "Run Fax test" The printer will then print out the results. It will tell you if anything fails. If it does, the correct the problem it mentions. IF everything passes, then the problem is likely your cable phone line which is a "Digital" and Fax machines still use an analog signal. Here is what you can try to overcome the deficiencies in a cable phone system. 1) Set your fax speed to Medium 2) Turn your ECM (Error correction mode) OFF
To set your fax speed, Press the SETUP button again.. Press your down arrow again until you find "Advanced Fax Settings" and the press OK.. arrow down until you find "Fax Speed" and hit OK. Then choose Medium (14,400) and press OK This will take you to your previous menu (Advanced Fax setings).. Find "ECM Choose OK again.. Then choose OFF and press OK. Press the X button on your printer's control panel and then Retry your fax.. Hope this helps
Jul 21, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
Jul 21, 2009 | IBM SureMark Printer TF6 Thermal Label
Printer wont turn on even the power supply is ok.
first open your printer and check the if the fuse in power pack is ok, the if is ok then check the wires if there ok the as for new printer mother board ok
Michael
Jan 27, 2009 | HP DeskJet F380 All-In-One Printer
HP 2180 deskjet all in one problems printing
Try this :-
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
Communication Error IM 200
ok..turn off printer..unplug from computer..
remove s/w for printer via print panel
go here, get new drivers
install
turn on printer
connect to computer
see how that goes
Mar 24, 2008 | Epson Stylus C86 InkJet Printer
Printer won't work, even if goes through printing motion, says ready, etc , shoots out paper.
Do you have the installation disk for either printer? If so simply reinstall over the existing ones. If you do not- Go to Start/printers and Faxes Clcick on install new printer. Select from list Select make Select model select OK
May 06, 2007 | HP DeskJet 648c InkJet Printer
HP DeskJet 810c InkJet Printer Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
