Question about Ariens Zoom 34" (Stamped Deck) Zero Turn Lawn Mower NonPowered Bagger
Does the ariens zoom 34" zero turn mower have an oil filter
philwalker78
  • 608 Answers
SOURCE: i need to know what type of oil to add to my
Hi, if it has a Briggs and Stratton engine you need sae 30 engine oil. Regards Phil.
Posted on May 01, 2011
SOURCE: blades won't turn to cut grass
On the chute where the grass comes out there is a black piece of metal under the edge of the deck held on by the 2 big thumb screws is probably bent. You will need to try to move the blade on the side near the chute by hand (Make sure the mower is not running when you do this) if the blade touches the black piece of metal it will kill the mower if you engage the blades and try moving forward. Anyway you need to take the black metal piece off and bend the corner out of the way (I used a crescent and clamped it to the hitch on my pickup). I am guessing i went over something like a street curb with the deck when it was to low and that bent it. Now when ever I move the mower from someones yard or drive it across the street I always raise the deck up all the way. I hope this helps
Posted on May 27, 2009
  • 3 Answers
SOURCE: The engine will not stay running (Ariens 34' Zoom)
a lawn mower is not much different than a car, you still need 3 things to make it run: fuel, electricity, and a spark. you say it doesnt stay running, Before trying to make any repairs, ensure that you are using the correct fuel, also make sure the fuel lines are not leaking or crimped. if the lines seem fine, check the fuel filter and/ or fuel pump. though the mower is new, they can still have faulty componets.
Posted on Aug 16, 2009
SOURCE: I just installed mulch kit on my Ariens 34
i'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
Posted on Sep 14, 2009
bbreton
  • 437 Answers
SOURCE: ariens zero turn will not start
Have you done a load test on the battery? It may be time for a new one 300CCA. Plus the solenoid may not be working right. you will know more because of lack of information or symptoms.
Good Day.
Posted on Nov 07, 2009
Ariens Zoom 34 will not move forward or back
suspect a damaged belt or tensioner spring for the drive belt... these units have no servicable trans-axles. or did you just remove both rear wheels ???
Nov 27, 2013 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Does the zoom 34" zero turn have an oil drain plug? if so, where is it located?
some of the newer engines have a oil drain that you turn a quarter of a turn that it drains look at the bottom of the dip stick tube
Jul 09, 2012 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Engine smokes on Ariens Zoom 1634 34 inch Zero Turn Riding Lawn mover with Briggs & Stratton engine
check to see if the oil smells like gas the needle valves go bad in the carb and overflows into the crank case also head gaskets go bad and **** oil in from the crank case
May 08, 2012 | Garden
How do ytou adjustadjust the steering on ariens zoom mower
The owner's manual tell you. If you don't one. Go to www.mowersdirect.com/manuals/zoom4250pdf and download one.
Feb 18, 2012 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Hi, i have a Ariens Zoom M 2148 xl tractor model
Probably you can get what you need at a lawn mower shop, they have exploede parts diagrams on microfilm.
Sep 28, 2010 | Ariens 34 In 344 CC Briggs Stratton...
Ariens 34 zoom blade binds at mid-height blade
Sounds like the mower deck is lower on one side. I am having the same problem with my older tractor mower.
Jul 24, 2010 | Ariens 34 In. Zoom Series Riding Mower
Ariens Zoom 34" (Stamped Deck) Zero Turn Lawn Mower NonPowered Bagger Logo
545 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
