Question about Samsung Digimax S600 Digital Camera
I've lost the set up driver and when i plug in USB cable the new device is not detected. How can i download the set up drive for Samsung S600 camera. Thanks in advance
  • 10,421 Answers
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Samsung external hard drive
!! You have failed to provide a detailed problem. !!
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Jan 29, 2013 | Samsung G2 Portable External HX-MU064DC/...
My laptop is saying Check Cable Connection!
What this means is that it has "lost" the windows installation. Possibly corrupted and possibly a virus
The message you are getting is due to the laptop looking for an alternative boot device, the PXE refes to network boot, the last in the boot order.
What you need to do is obtain a copy of the Windows disc, borrow a USB CD Drive and re-install. When getting to the install windows prompt, let it "find " the windows installation and REPAIR
If you do not have a USB device, the following is your only other option:
  1. You will need the following: Copy of a windows installtion disc; usb pendrive of 2 gb, probably aslo a usb floppy drive and floppy disc.
  2. You will also need this:
http://wintoflash.com/home/en/
  1. Now you need to borrow a computer to download the above software and visit the Acer download page to get the SATA drivers. Extract these to a floppy drive and make sure you have the TEXTMODE drivers!
  2. Run win to flash and extract the windows files from the cd, it will guide you through the process of making a BOOT Usb.
  3. Set laptop bios to boot from USB
  4. When prompted (have the floppy usb drive plugged in), at F6 press to detect the SATA drivers on teh floppy
  5. Follow instructions and you should have windows up and running again
Feb 09, 2011 | Acer Aspire One D255-2670
Cant detect my samsung star s5233a phone to pc
Hi, do one thing, i think you may have version 1.1.2.ICE of samsung new pc studio,which was came with mobile. uninstall it along with all drivers of modem. Now go to samsung website,and select yr country(like india) and download latest version 1.1.2.ID3. and install it. do not install usb modem drivers. and connect the mobile,it will be decteted by the windows ,and installed and ready to use window will popup. Start samsung new pc studio,and enjoy. i was also puzzlede by this, but now find this solutionit works 100 percent ( i`ve windows xp).
Aug 03, 2009 | Samsung SGH-L700 Cell Phone
Samsung Pleomax SAM MD-205 driver?
It took me a lot of digging to try and find a driver download. You can try the UHD25-80GB driver (this is for Windows 98, but you can try to see if it fixes the problem): http://www.samsungpleomax.com/sup_03_01.asp?page=2&fcate=Driver+download&scate=Storage+Media&tcate=HDD&scateg=Storage%20Media&tcateg=HDD. Direct link to zip file: http://www.samsungpleomax.com/sup/cs/HDD-driver-2500-80GB%20DRIVER.zip
Also, specs indicate that you need USB 2.0 or 1.1. I had problems connecting via a 4-port hub (that was supposed to support USB 2.0) so ended up connecting directly via my computer USB ("Enhanced" = 2.0) slot, which seemed to work fine.
Apr 04, 2009 | Samsung Zirex Pleomax 80GB Portable Hard...
Vista won't recognize my phone.
You need to go to the samsungmobile.com and download the vista drivers for the phone
Sep 10, 2008 | Samsung SCH-u740 Cellular Phone
Web cam installation
hi
check the usb settings enabled in the bios or the cable inside the laptop.In some case the usb cable inside get fault and it will not detect the web cam.In normal case if you plug any usb device it will detect the usb device then the os will show new hardware found and will allow you to install the software for it,if it doesnt detect you cannot install the driver for it and in the yahoo messenger it give the message
May 26, 2008 | Creative Labs WebCam Live!
USB not decting plug n play devices
I would check the bios settings to make sure the motherboard settings relating to PnP are correct. Try playing around with those bios settings and see what works for you. Also try different usb ports, i have the same problems sometimes with certain ports on my desktop computer, try all of them at the front or the back of the computer. I would check the Compaq Presario website for drivers not AMD, installing new ones is a good idea just to make sure its not a driver issue.
Dec 21, 2007 | Computers & Internet
Device not detected
download the usb drivers
Jul 29, 2007 | NEC MobilePro 900c Pocket PC
Samsung Digimax S600 Digital Camera Logo
47 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
