Question about IBM ThinkPad T43 Notebook
Bought a used T43 and want to find instructions for turning on the display light and turning back on my finger scroll pad app. etc. My access IBM button does nothing. I assume there is an onboard tutorial/manual somewhere but can't find it.
    Sergeant:
  • 226 Answers
Go here:
http://www-307.ibm.com/pc/support/site.wss/migr-58315.html
and download your user manual.
tom
Posted on Oct 11, 2010
What causes a thermal sensing erro on ibm t43
A Thermal error on the T43 usually indicates a problem with overheating. This can be caused by many reasons:
1. Dirt build up on fan or fan louvres causing fan to turn slowly and not being able to cool the system properly.
2. Blocking of air inlets to the laptop. Do not use on your lap, or on soft surfaces such as blankets, bedsheets, etc.
If you feel a lot of heat from the air out of the laptop, then the system is over heating.
You can run fan diagnostics as follows:
1. Turn on the computer and check the air turbulence at the louver near the PC Card slot.
2. Run Diagnostics --> ThinkPad Devices
--> Fan.
Here is the T43 maintenance manual to see how to check and or replace the fan.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6193.pdf
May 08, 2014 | IBM ThinkPad T43 Notebook
Can't see my onscreen display after turning on F7 IBM T43 ThinkPad
set it to clone. it should give you identical displays. then try setting it to extended display. But make sure that your laptop display is primary display. That is why your external screen is displaying because it set on primary.
Jul 21, 2012 | IBM ThinkPad T43 Notebook
I have an ibm t43 and the top of the screen is glitching to where it has white lines on it. How do i fix it?
Problem may be;
1) Video Cable:
A) May have a loose connection on the motherboard side, or back of LCD screen side.
B) May be damaged.
2) Display Assembly:
Specifically the screen Inverter, or LCD screen.
Primer:
An LCD screen does not produce light.
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology) can be a CCFL, (Or dual CCFL's), or a series of LED lights.
The IBM T43 series of Notebook PC's uses a single CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size of bulb is;
1) Width: 2mm. {Slightly more than 1/16th of an Inch }
2) Length: A little shorter than the LCD screen is in height.
Basic example,
http://www.ebay.com/itm/14-1-XGA-CCFL-BACKLIGHT-LAMP-IBM-THINKPAD-T42-T43-/270965162524?pt=LH_DefaultDomain_0&hash=item3f16c8421c )
The screen Inverter converts power from the laptop for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault is the screen Inverter.
Primer over.
Example of Inverter,
http://www.batterycentury.com/lenovo-ibm-thinkpad-t43-inverter-p-186266.html
The thin plastic 'frame' in front of your LCD screen, is the LCD Bezel.
(Goes by several names, depends on manufacturer.
Display Bezel, Display Panel Bezel, LCD Bezel, LCD Front Bezel, etc.)
Behind it, and located at the bottom of the LCD screen, is the Inverter.
IBM ThinkPad T43 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
Go down to the line that begins with ThinkPad T20. (T20 in blue)
Scroll across, click on - T43
[ This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { T43 } it may take up to 30 seconds, before the first page comes up ]
A) ALL power removed. Remove the AC adapter (Charger) and Battery.
B) It would be BEST, if you would wear an ESD wrist strap. Have it's alligator clip connected to a good ground source.
(Electro Static Discharge)
Average price of an ESD wrist strap is $3 to $6.
One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
C) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Do NOT mix them up.
1) Check the connection of the Video Cable TO the motherboard, and TO the back of the LCD screen.
NOTE*
The connection MAY look to be plugged in tightly, but in reality it is not.
Physically make sure the cable is plugged in tightly.
(Especially at back of LCD screen )
You have to remove the Display Assembly from the laptop, in order to properly access the video cable connection, at the back of the LCD screen,
NOTE*
PDF file page number, and service manual actual page number, Do Not match. When I refer to a page, the reference will be to the PDF file page number.
Go to Page 121 in the Service Manual, for units that have a 14.1 Inch LCD screen.
Page 126 for 15 Inch.
Motherboard Connection:
Laptop open, looking at the LCD screen; The cables on the Left are Video. The cables on the right are for the Wireless Antenna.
LCD screen connection:
Disassembly of LCD Assembly starts on Page 154.
Page 167 shows the video cable, and connection.
LCD flat panel cable = FPC. Also known as Video Cable.
On Page 121 you will see a component removal list, listed in order of removal.
You can click on an underlined subject, to go directly to the chapter that deals with it
To remove the LCD Assembly, (Display Assembly), you have to
remove the Keyboard, then Keyboard Bezel. (Palm Rest)
Once the Keyboard Bezel is removed you have direct access to the motherboard connection side, of the LCD cable. (Video Cable, or for IBM - FPC)
Check the connection. Tight or loose, you still have to check the connection at the back of the LCD screen. (LCD Panel)
1a) Check for damage to the LCD cable.
If there is obvious damage to the outside sheath of the cable, there may be damage to the tiny wires inside the cable.
Even if there isn't obvious signs of damage, the tiny wires inside may be stretched/broken.
Use a multimeter set to Ohms, and check the continuity of the wires, inside the LCD cable.
{ An economical, yet good enough for this test multimeter, can be purchased for as little as $8 to $12. Available in a multitude of stores. An auto parts store is but one example. Analog or digital is fine }
2) LCD cable checks out it's on to the screen Inverter.
Make sure this small circuit board isn't damaged. (Pulled wire/s)
To test a screen Inverter requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
Something the average consumer does not have.
For this reason, the ease of accessing it to replace, and the usual low cost, (Compare to an LCD screen), the unit is usually just replaced.
Parts changing I know, but you have to use what is available to you.
Or see what a computer repair shop will charge to test the unit.
[ NOTE*
An LCD screen, and a screen Inverter are a MATCHED unit!
When replacing make SURE you get the right part ]
3) Screen Inverter checks out it's a bad LCD screen.
NO, your graphics chipset is FINE.
For additional questions, or clarifications, please post in a Comment.
Regards,
joecoolvette
Apr 27, 2012 | IBM ThinkPad T43 Notebook
Touch pad is disabled and cannot enable it
There will be a function button on the keyboard to turn it on and off, look at all the f1 f2 etc keys and look for a mousepad symbol and press fn + that button.
Jun 19, 2009 | IBM ThinkPad T43 Notebook
T43 laptop bios not starting
download partition manager it`s freehttp://www.partition-tool.com/personal.htmand you can format,create ,resize etc your partitions...BACKUP ALL DATA BEFORE MESSING WITH PARTITIONS!!!update bios first just make sure it`s right model number(read instructions)http://www-307.ibm.com/pc/support/site.wss/MIGR-59096.html
Apr 21, 2009 | IBM ThinkPad T43 Notebook
Double display with my IBM think pad T43
have you tried Function F7/F8 ?
Make sure that your display driver is installed correctly.
I had the same Laptop as you did and was able to have dual monitor.
Also check your Display driver in your control panel and make sure it set to dual monitor.
May 12, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
106 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
