Question about Frigidaire Washing Machines
How do I replace a drive belt on a Frigidaire Washer, Model FWS645RBS4?
  • 770 Answers
Reomove the front panel then you will see the belt you can slip it on the motor pulley first then you will need to push in the idler pully to spin it around the transmission pulley
Posted on May 31, 2008
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Drive belt replacement aft7000
Good Afternoon Friend,
I understand you want to know how to replace the drive belt in your Frigidaire washer, model# ATF7000. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to replace the drive belt with ease. Hope this is helpful.
-Best Regards-
Jul 09, 2014 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire stackable model FEX831CS0 won't agitate or spin
Hi Kathy.
If the washer does not agitate and spin, then the most common problem is the belt: Washer Drive V-Belt (part 28 in diagram 1)
If you can manually advance to spin but the machine does not agitate, then parts that may need to be replaced are the agitator:
Agitator (part 11 in diag 1) or the agitator drive in the transmission:Agitator Drive (pt.2 diagram 2)
To replace the belt remove the assembly at front top of the washer held by two philips screws and clips. Here description of replacement procedure.
Here Diagram 1
Here Diagram 2
Nov 18, 2011 | Washing Machines
I have a Frigidaire GLTF1670A washer. When the washer goes into the spin cycle, I have noticed a progressively louder belt slipping sound. The washer is 7 years old. Do I need to replace the belt, or is...
Disconnect the washer from the electrical supply then remove the screws shown holding the rear access panel to the washer’s rear panel and lift the access panel off.
Cushion the bottom of the cabinet opening as shown to avoid hurting yourself with the sharp edge.
Plug the washer in then start a loaded spin cycle to check for belt slippage and the motor operation itself.
Replace the belt if loose or slipping. Remove the belt by turning the tub drive pulley and rolling the belt off the pulley.
Install the new belt in reverse order by wrapping it around the motor pulley and on one side of the tub drive pulley then turn the pulley to the other side in such a way that the belt wraps completely around the pulley. Secure the rear access panel back into position to complete the procedure.
Note: This advice is intended solely for the asker dolanbox as per live chat discussion.
Aug 30, 2010 | Frigidaire GLTF1670A Front Load Washer
I am trying to find the right dryer belt for FEX831FS1
available through sears but the part number is
16.00 dollars
Oct 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Aug 21, 2009 | Frigidaire FEX831CS Top Load Stacked...
Non-spinning washer
Have you checked the motor? Make sure that the motor is turning properly and also make sure that your belt it not to tight. It should have some give in it. If none of that works then look at the main bearing under the pulley on the drum
Feb 10, 2009 | GE WNSE6280BWW Top Load Washer
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Non-spinning washer
Do you hear the motor running when it doesnt spin? Is the belt still over the idler pully between the drive pully and motor pully? Does the lid switch operate properly? Need a little more information if you can. Give me a shout back, and we'll figure it out. Jim
Oct 31, 2007 | Washing Machines
Washing Machines Logo
121 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
