Question about Lexmark Office Equipment & Supplies
I have just got a new computer and it has windows 7 its operating system is 64-bit. the printer i want to share with this new computer is x5690 and i am having major problems in getting my computer set up with this printer. i have deleted the printer off and then set up a new one i first had a message about incorrect port detected so i started to go down the list of ports the first few said the same thing the port that is checked off is LPT1 the description being printer port and the printer saying lexmark 5600 - 6600 series . i wondered which port its supposed to be on as before i got the new computer i was able to share with the printer from the other computer which is the host for the printer. just to also include i left the homegroups on both then joined the other computer homegroup after setting it up on the host computer with the printer.
  • 340 Answers
Have you tried downloading the updated driver for windows 7 64 bit? This may help.
Posted on Oct 11, 2010
I share the printer epson plq 20M in window 7 64 bit, but not working correctly. the printing unknown font. How to solve?
check that both computers are using windows 7, then use printer setup wizzard to set it up for you.
Jan 06, 2015 | Epson Passbook PLQ-20 Matrix Printer
Windows cannot connect to printer. Operation failed with error 0x0000007e.
This problem happens when you are trying to share printer between 32 bit (x86) and 64 bit (x64) Windows. The 32 bit driver not compatible for 64 bit operating system. At this situation you may get error message like this "Windows cannot connect to the printer Operation failed with error 0x0000007e".
But there is an alternate way to add printer from 32 bit Windows to 64 bit Windows.
Start >> Devices and Printers >>
Then Add Printer with the help of IP address of 32 bit Windows computer.
Detailed steps with screen shots are given in the following link.
[Solved] Operation failed with error 0x0000007e
Solved Operation failed with error 0x0000007e Share printer between 32...
Apr 11, 2012 | Xerox Office Equipment & Supplies
OS is windows 7 and i want to connect lexmark p4350 inkjet printer
Use the Lexmark P4350 printer driver for Vista OS on Windows 7. But first, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to download and install the printer driver on your computer:- Lexmark P4350 Printer Driver for Vista 32-bit or Windows 7 32-bit- Lexmark P4350 Printer Driver for Vista 64-bit or Windows 7 64-bit
Simply follow the instructions on your computer screen to complete the installation.
I hope this helps. Thanks.
Nov 14, 2011 | Lexmark P4350 All-In-One InkJet Printer
I have Lexmark Prestige 805 It seems like I keep losing my printer connection, I have to turn the power off the printer and back on again to make it work or re-download the print driver. I used to have...
Please follow the steps below to fix the problem you are experiencing:
First, uninstall your existing printer driver from your computer.
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark folder.
  4. Pro800 Series folder.
  5. Uninstall Lexmark Pro800 Series.
After the uninstall process, reboot your pc when prompted. When your computer turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type if it's a 32-bit or 64-bit.
Second, use the link below to download and install the Lexmark Prestige Pro805 driver for Windows 7 from the Lexmark website. Use the correct driver for your operating system.
- Lexmark Prestige Pro805 Printer Driver for Windows 7 32-bit
- Lexmark Prestige Pro805 Printer Driver for Windows 7 64-bit
Follow the instructions on your computer screen to re-install the printer driver.
Sep 01, 2011 | Lexmark Prestige Pro 805 Color All-in-One...
I installed hp lajerjet 3050 on windows xp 32 bit...and on another laptop having windows 7 64 bit operating system. when i am trying to share the printer on windows 7 64 bit...it shows drivers not found.
Same Driver will not work for win7 64 bit even if you share the printer it needs the driver for win7 64.
You will have to download the driver for win7 64bit and install in that system.
http://www8.hp.com/in/en/support-drivers.html
Aug 02, 2011 | HP LaserJet 3050 All-In-One Printer
I am trying to set up a home network, between my laptpo, which is running Vista, and my desktpo which is running Windows 7. when I install a driver, I keep getting AIOC.exe has stopped working. Can sombody...
I suggest you use the driver from the Lexmark website. You may need to uninstall the existing Lexmark X1270 driver first before installing the new one (instructions on how to uninstall the Lexmark software available at http://bit.ly/8ZH59T). Then, check if your Vista and Windows 7 are running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. Download the compatible driver for your operating system:
Thank you for choosing Lexmark.
Oct 30, 2010 | Lexmark X1270 All-In-One InkJet Printer
Cannot install HP Deskjet 3745 in Windows 7 64-Bit Operating System Options Hello, I have a HP Printer with the following details, 1. Model Number -HP Deskjet 3745.(Color Inkjet Printer). Upto...
Open the Devices and Printers folder
Right click on the Printer icon and Click on Troubleshoot
Follow the instructions and finish the Troubleshooter Wizard
You should be able to print
Sep 22, 2010 | HP DeskJet 3745 Printer
Is the lexmark X6650 wifi printer compatible with windows 7 Have an HP Touchsmart 300 with Windows 7
Hi. Yes, your X6650 wifi printer is compatible with Windows 7. Check if your computer is running on 32-bit or 64-bit Operating System by going to Start > right click on Computer > Properties. Then, go to this link. http://bit.ly/agMj9j . Click on Microsoft tab on the center of the page. Download the correct driver. cj6600Win7en32.exe is for 32-bit operating system and cj6600Win7en64.exe is for 64-bit Operating system. Hope this helps.
Mar 11, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
I have a new computer and it says that I cannot install this printer on the new computer
DRIVERS
HP Officejet Pro 8500 All-in-One Printer - A909a
HP Officejet Pro 8500 Premier All-in-One Printer - A909n
HP Officejet Pro 8500 Wireless All-in-One Printer - A909g
for following Operating System
» Microsoft Windows 7 (32-bit)
» Microsoft Windows 7 (64-bit)
» Microsoft Windows Server 2008 x64
» Microsoft Windows Server 2008 W32
» Microsoft Windows Vista
» Microsoft Windows Vista (64-bit)
» Microsoft Windows XP» Microsoft Windows Server 2003
» Microsoft Windows Server 2003 64-Bit Edition
» Microsoft Windows 2000 Server
» Microsoft Windows XP x64
» Mac OS X
» Linux
Jan 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
87 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
