Question about Danby DDW496W Free-Standing Dishwasher
Danby counter top dishwasher
Hi
My dishwasher is over a year old. I hardley ever use it. But I turned it on last night to wash os glasses. The water went in but then the arm didn't sprinkle and nor did it come out. Do you think it could be some kind of bluid up or something like that?
    Problem Solver:
  • 6 Answers
CLR should do the trick, read instructions on back of the bottle. Also there are some dishwasher cleaners that you buy.
I bought one at Safeway. Small bottle, has a picture of a dishwasher on it. It has a wax seal that melts when you run it on the hottest cycle upside down. It cleans the inside of the dishwasher.
Of course this is assuming that its build up.
Posted on May 02, 2009
Danby counter top dish washer spray bar don't turn
Remove it and make sure it is clean. They work by the water force going through it, if it's dirty the water can't go through and so can't turn.
Aug 09, 2014 | Danby 6 Place Setting Energy Star Counter...
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
I have a Bosch SHU3036UC dishwasher. While sitting idle - during the day or over night, it fills up with fresh water. I shut off the water supply last night and this morning it was dry. Any ideas?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 12, 2011 | Bosch SHU3036UC Dishwasher
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
Soap suds and some water not draining out of washer after cycle is complete
if you read the manual, it states that this is normal. so dont let this bother you
May 05, 2009 | Danby DDW496W Free-Standing Dishwasher
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
Water will not drain out of dishwasher
trace it back along the outlet pipe and you will find on the pump a unscrewable plug be carefull as you are going to get a few litres of water over the floor
Apr 08, 2017 | Hotpoint 24 in. HDA1000Z Built-in...
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Water filling then emptying again right away
Take the cover off, as you face unit on right side follow the vacum hose to two presure switches. Tap on them lightly with a the handle of screw drive. fix my unit three months ago still working. The problem is the presure switch.
Dec 08, 2007 | Danby 22 in. DDW396 Free-standing...
Ultra Wash
Sounds like your not getting water to it. Turn on and let run for a few minutes then open door and check to see if you have water in it.
If not check to be sure water to it is turned on. Check float in front corner of dishwasher to see if moves freely up and down and that there is nothing underneath it. If these check ok you probably need a water valve.
Nov 03, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Danby DDW496W Free-Standing Dishwasher Logo
279 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
