Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ksra25ilss13 my thermostat is not working properly not turning off I have kitchen aidsuperba side by side
Oven heats up to set temperature of 500 degrees, and shuts off completely on its own. replaced electronic control, and it still does the same thing. Any suggestions??
Does it have a thermostat to regulate the temps? If it is working correctly it will turn the element on and off to maintain the set temp.
There is also some thermo couple in there to regulate the flow of gas. If that goes haywire gas does not flow properly and ........
Nov 24, 2015 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Why is my oven burning baked goods on the outside but still raw on the inside, when baking at the correct temperature setting?
Sounds like you need to set your thermostat as its not reading properly. Ours has a little screw on the side of the thermostat and I use an oven thermometer to make sure the heat is right. Ours was twenty five degrees out.
Dec 16, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
Room Thermostat--Right near heater
First move that fridge!! Constricting the airflow like that not only makes the heater cycle too much... it's a safety hazard.
Once you allow the heat to circulate properly you can address the issue further.
Oct 26, 2013 | Heating & Cooling
My gas oven, Super Capacity 465 the oven nor broiler light. The stove top works fine.
Hello there
Please read the entire solution i have provided below ok
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Sep 28, 2010 | Whirlpool GS460 Gas Kitchen Range
Cannot remove thermostat without shutting off gas?
the cap tube from the thermostat goes in the oven from back then 2 clips on the side hold it in place....I don't see a need to shut gas off but you(by law) should have a turn off valve...it's just a good thing to have...you must have a valve to the house don't pay your bill they will find it fast..thumbs up
Aug 15, 2009 | Hotpoint RGB524 Gas Kitchen Range
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Mar 04, 2009 | Garland H283 Gas Kitchen Range
Oven doesn't heat up properly
ovens can be calibrate for the right temperature. the adjustment screw is locate inside the shaft of the thermostat. when you remove the oven knob.
Nov 15, 2008 | Whirlpool GS460 Gas Kitchen Range
Tappen model TGO356BCW top oven
replace the igintor. its not working properly. no doubt you have a bad ignitor
Mar 15, 2008 | Tappan TGF320 Gas Kitchen Range
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
64 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
