Question about Saeco Magic De Luxe Espresso Machine
My Saeco Magic deluxe is leaking water from steam wand. Ideas?
mirran
  • 515 Answers
SOURCE: Saeco Magic squirts water out the wand when brewing
Hi Steve,
You have to replace the gasket on the steam pin, maybe you have to replace the steam pin to if it is worn.
Posted on Jul 12, 2008
SOURCE: water leaking from steam wand when brewing shots
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Posted on Dec 29, 2008
SOURCE: water leaking from steam hose on Saeco Italia
There is a part that the hose connects to and it is made of plastic. The plastic on mine had a tiny split in, which caused it to leak. I got a replacement one made of brass and that problem is fixed. Now my machine is broken in another way and I am hoping to get it fixed. What a piece of junk!!!
Posted on Sep 29, 2009
SOURCE: Saeco Magic Deluxe water leak
bansheracer-
I have the same problem with the boiler leaking, and I'm also guilty of not descaling nearly enough. Anyway, I've already replaced the machine, but I just can't bring myself to throw away this otherwise great machine. I've ordered a boiler repair kit and I want to attempt a fix on my own (don't want to spend too much money). I have the machine opened up, but I'm not sure how to remove the boiler. Do you have directions?
Thanks.
Posted on Feb 02, 2010
SOURCE: Saeco magic deluxe is leaking water
I just fixed a leak caused by a worn o ring in the body of the steam dispenser control. It was pretty much spraying water inside the machine and shorting the circut. It took a couple of hours to work out, but in the end only cost me 50c to fix.
Posted on Feb 14, 2010
What PURGE means
Means to run Hot water through the steam wand... Also called ventilating the machine. Basically running water through the machine the easiest way possible which would be through the steam wand. On the magic deluxe all you have to do it turn the steam knob.
here is a page that may help you now or maybe some other time. http://www.cerinicoffee.com/item-group.asp?pgpID=13
Jun 06, 2011 | Saeco Magic De Luxe Espresso Machine
How do I ventilate my Saeco Magic Plus?
Open the steam/ hot water tap ie: run hot water through the steam wand.
Dec 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
My saeco magic coffee machine says ventilate.How do I do this?
Hi
If it is just a Magic Delux, open the steam knob, without pushing the steam button. If its a Magic Comfort you have to push the button with the drops on it and it will flow water.
Apr 10, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Delexe water light flashing
The brew unit is blocked, check the shower screen under the red o-ring.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Water pump?
If you could brewer coffee or get hot water out of the steam wand then it could be the one way valve on the bottom of the water tank. If you are running the pump output into a glass then it is probably scaled up in the boiler.
Jan 02, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic deLuxe shorting
this is from steam condinsation inside the unit (check all hoses for leaks also check seals!)
Please rate responce and help keep this site free!
Dec 20, 2008 | Saeco Magic De Luxe Espresso Machine
Magic De Luxe Frother won't work!
means you do have the hot water button pushed and not just the steam function.
Follow this SAECO
Jun 03, 2008 | Saeco Magic De Luxe Espresso Machine
Filter in saeco magic delux
little magnet keeps that red light from coming on.
magnets probably gone bad, need to buy a new water tank. As far as i know saeco does not sell the magnets seperate.
could also be a blockage sending the machine into alarm.
May 08, 2008 | Saeco Magic De Luxe Espresso Machine
Hi Steve,
Apr 11, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Saeco Magic De Luxe Espresso Machine Logo
73 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
