Question about Car APS997A Two-Way Remote Start and Security System
I have a remote start for my car (2005 Cadillac CTS). It has a picture of the car. How can I unlock the trunk from the outside of the car.
  • Audiovox Master
  • 625 Answers
The APS 997A has two outputs for trunk release. The output and function button depends upon which wire the installer used. If he used the dedicated trunk release wire; press and hold (approximately 4 seconds) the green button that has a picture of the trunk and a key on the button. If the installer used the auxillary wire; press and release (1 second) the option button on the remote.
Posted on Oct 12, 2010
What is the correspondence fuse called for trunk release for 2005 Cadillac CTS
Look in your owners manual to find the location of the fuse to check.
Jun 10, 2016 | 2005 Cadillac CTS
2008 Cadillac CTS rear passenger door wont unlock with the remote. all other doors and trunk work. must manually lock and unlock door that door. anyone know what the issue is, and is that something I...
see the diagram attached. YOu must test the mechanism for lube, or damage parts, loose wires or connector corroded, switch dirty Lube WITH wd-40, test the motor or solenoid
God bless you
Nov 27, 2013 | 2008 Cadillac Cts
Trunk won't open with either remote but will open with trunk button on drivers door
I would check the owners manual or with Cadillac - its possible the remotes lost part of the signal and need to be reset. It sounds like the receiver is not getting a signal from them by using that button.
Could be the receiver too.
Sep 27, 2012 | 2005 Cadillac CTS
How to change a license plate bulb on a Cadillac Cts
Yep this answer is correct!! Remove the panel on the inside of the trunk, remove 8 10mm nuts, carefully pull of entire light assembly, and you will see the tag light bulb carrier. Turn it to the unlock position, and replace the peanut style bulbs, they just pull out of the socket.
Feb 05, 2012 | 2005 Cadillac CTS
The light cover on the outside of my 2003 cadillac cts broke what is the proper name for it how can I find one
Call your local GM, Chevrolet, Cadillac, dealer and ask for a light cover for the trunk light!
Dec 04, 2011 | 2003 Cadillac CTS
How to program 2005 CTS remote?
YOU CAN SYNCHRONIZE REMOTES IF REPLACED BATTERIES. BY STANDING WITHIN 5 FEET OF VECHICLE.PRESS ANY BUTTON ON REMOTE TRANSMITTER TO RESYNCHRONIZE.REMOTE SHOULD NOW LOCK AND UNLOCK VECHICLE.TO REPROGRAM REMOTES YOU NEED DIAGNOSTIC EQUIPMENT WHICH THE DEALERSHIP HAS TO FIX.
Jan 27, 2011 | 2005 Cadillac CTS
I have a 2005 CTS cadallic And I cannot open the trunk with my remote or my button oin the drivers side door panel. What do I need to do?
Open the trunk manually. Pull down the back seat armrest and open the door for trunk access. There is a yellow handle that is above the door, pull the handle and the trunk will open manually.
The remedy for your problem is probably the fuse that runs the solenoid to the trunk opener, it is found under the rear seat passenger side. It has a black cover over it, remove the cover and find the corresponding fuse.
Aug 01, 2010 | 2005 Cadillac CTS
On my 2005 cadillac cts the long light on the trunk of the car does not work
check your manual in electric lights and panels u may have a bad light or bad fuse good luck
Nov 05, 2009 | 2005 Cadillac CTS
2004 cts cadillac trunk will not open with remote or button on drivers door.
Check fuse.. Test for power to trunk release solenoid. When door button, or remote trunk release button is pushed. If there is power ( use a 12 volt test light ) most probably faulty release . Hope this helps
Apr 23, 2009 | 2003 Cadillac CTS
Car APS997A Two-Way Remote Start and Security System Logo
184 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
