I've got a Pioneer PL-300 turntable bought around the mid-80's. It hasn't been used much in years, especially due to a problem with the tone arm lifting up before the end of a record (45 rpm) has finished (there is usually about 1/8" groove material left to go when it does this). Also, the other thing is - if the tone arm does track the record grooves right up until the end (I tried putting a shim underneath both of the rear feet last week, and this helped here - maybe the unit wasn't quite level) there becomes this light 'clicking' sound coming from the tone arm pivot and at the same time the needle starts to jump as if it wants to resist going forward any more - right up until the end of the record. This usually starts around the 1/8" to go area on the record. Has this got anything to do with the auto return mechanism? I've tried adjusting the anti- skate and balance as per the instruction manual, but this doesn't help. Any suggestions please? Sincerely, Michael Carpenter (carpenteria777@rogers.com)
  • 1 more comment
  • Anonymous Jan 02, 2009
    I have the same problem but with the PL-300X, which is basically the same player. The auto-return kicks in with about half an inch of the last groove to go. I would appreciate if someone had a solution for me.
    / Albin
  • mikey29 Jan 04, 2009
    Sunday, January 4, 2009
    Re: Solution suggested by Rocksteady01
    Many, many thanks for your explanation and solution about the adjustment needed on the Pioneer PL 200 turntable and for taking the the time to provide photos also - this made a lot of difference!
    The mechanism was adjusted this morning and within a quarter of an hour was back to normal, operating as when new. (I could never figure out why with so little use there could be much wrong that needed fixing).
    The unit has been that way for at least five years and Pioneer doesn't carry parts any more, there's just aftermarket. Also, there
    doesn't seem to be many places that repair turntables either nowadays. I can't get over how straightforward it was to put right.
    What made matters worse was after getting some software enabling you to transfer vinyl material directly to your computer hard drive, to copy to CD or MP3, this had to be put on hold due to this problem of the tone arm lifting too soon or the annoying clunking sound on the last few grooves of a record, which ended up on the recording.
    After all that time!
    Thank you very much and a Happy New Year.
    Sincerely,
    Michael Carpenter
  • kamz123 Sep 15, 2009
    That lever seems to prevent the arm from moving through its range, prevent reassembly. How do I put this back together correctly?
Hi Mikey. I shure hope you have solved your problem by now, but for everyone else, I woud like to shead some light on this matter. What you need to do is to adjust the auto-return lever that is located between the center of the platter and the tonearm, underneath the plastic cover. To do so, you first need to remove the platter so that can reach the adjustment-screw.
This is how the lever looks like in my PL-300X and it should look the same for you. I've marked the adjustment-screw that can be reached through a hole under the platter.
and this is what it looks like with the cover on:
Hope this can solve your or anyone elses problem.  Ciao / Albin
Posted on Jan 03, 2009
  • Stephen Heyse
    Stephen Heyse Feb 25, 2014
    Wonderfully clear and helpful fix. I was having the same problem playing old 78s.
Thank's Rocksteady01, I had the same problem with my Pioneer PL-300X and I tried to fix it myself with your discription and foto!!! saved me lots of money (to let it repear), and it took me about 2 hours to find out and to try out what's the best moment for return. By turning the adjustment-screw in another position and try when the arm returned I got adventually a good return-position after three times.
When assemblage: pay attention to the 'cut'-system; Be sure that the inside one has the right position.
Posted on Jan 27, 2009
How do I access tone arm belt and motor on a Pioneer PL-L30 turntable?
Try lifting up the turntable mat. You should see a hole. Note how it fits before removing the belt.
Oct 10, 2014 | Audio Players & Recorders
Repairing tone arm of a pioneer PL 200!
i have the same problem with two vestax parts, which of one is round so sprayglue and three turns around it with thin koper cable.and after that sandpapered itagain and another layer glue, but i had no choice... the part ain't available en a couple of days ago my backside of a pdx 2000 spantanious broke of, but carbon wil hopefully fix it. You need to know of which plastic it's made and get the right glue, but you nee some glassfibre orso also on the inside , or it will brake
May 11, 2014 | Vestax BDT-2500 Turntable
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
How can i use a pioneer PL-Z93 turntable with a pioneer A-717 amp?
Hi, there is no reason for the turntable not to work with your amp. This amp has 2 phono inputs. Moving magnet and moving coil. Your tt likely has a moving magnet cartridge fitted so connect via that input. Cheers John. styluscity.com
Nov 14, 2011 | Audio Players & Recorders
What do i need to hook the Stanton T.80 up?
Turntables are simple if you've an amplifier with inputs labelled PHONO (not to be confused with audio plugs called phono or RCA)
If your amplifier hasn't then the sound from the cartridge on the arm won't be good quality.
To make it compatible with a line input usually labelled either that or AUX you'll need a phono converter box. There are quite high price ones but there are equally mid and even low-ish priced ones too.
Look around online for Phono-to-Aux adapters, converters or whatever description and/or visit electronic stores like Radio Shack (still in the USA) or Maplins (UK) if you're near any.
Sep 21, 2011 | Stanton T.80 Turntable
Hello i have a pioneer pl-300 turntable. i bought it used and it's been working fine until today. now the needle skips ahead on the record. i am VERY inept with technical knowledge of turntables i just...
if its skipping ahead Almost like the needle is just gliding across the Record. It means your needle is bent, dirty or broken, Take it off and look at it closely.
May 30, 2011 | Pioneer Audio Players & Recorders
Pioneer turntable is powering up but not not spinning?
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 18, 2011 | Pioneer PL-990 Turntable
My Pioneer PL-570 tone arm returns but will not shut off. It keeps playing like the repeat button is on. I asked this question before and you replyed that on page 8 of the service manuel it shows the...
I have a possible solution to your problem, but will need to talk you thru it. You can register at AudioKarma.com and send a private message to Ghazzer.
Jun 25, 2009 | Pioneer PL-990 Turntable
Pioneer PL-570 turntable (c.1973)
Yes first check is that the Gnd wire from your turntable is connected to the Gnd (ground) post at the back of your amplifier with a good clean tight connection.
If the problem persists, check ALL your hi-fi components mains plugs for earth connections including your turntable, then remove the earth connections on all but one component so that you are left with only item earthed.
What does sometimes cause problems is if 2 or more hi-fi separates are earthed and connected to each other the earth cables along with the hi-fi interconnects form an inductive loop that picks up interferance such as mains hum etc.
Regards John
Sep 16, 2008 | Pioneer PL-990 Turntable
1,980 people viewed this question
 Grubhead
Grubhead
