Question about Panasonic 600W DVD+VCR Home Theater System SC-HT822V System
Have technics sh-eh600 and i have no bass coming from the main speakers even though they are wired correctly
3 Suggested Answers
Palmbeach
  • 185 Answers
SOURCE: no sound from turntable bought for our hi fi system
Hi droopydraws
I don't know this specific system, but the connections are much the same on most set ups.
Turntable sockets on most amplifiers are referred to as "phono." So the first thing to do, is look on the back of the tuner/amplifier for a pair of sockets that are marked "Phono - L" and "Phono - R." The L and R are for left and right. Connect your turntable should be connected to these sockets. Your tuner/amplifier should have a button or setting to select "Phono" and you should then hear sound from your turntable. If it doesn't work there are two possibilities.
1) The phono input on the back of your tuner/amplifier might be faulty. You can check this very easily by temporarily plugging your CD player or Cassette Deck into the phono input sockets then selecting phono as if you were using the turntable. If there is still no sound, there may be a problem with the switching circuit. If there is sound, the problem will be associated with your turntable. Please note, anything plugged into the phono input will sound tinny, except the turntable because the frequency response is set for optimum sound quality when used with a turntable and not with other sound sources.
2) If you suspect the turntable, carefully remove the headshell and look at the small connections to the stylus, ensure they are firmly pushed onto the pins.
Hope this helps. Regards
Posted on Jan 16, 2008
SOURCE: technics sa-eh600 displaying u70cd can you help me
Your cd player is not connected
Posted on Nov 03, 2010
My technics sh-eh780 stereo seems to work but the sound is very dull in sound
Unless there's an issue with internal components of the amplifier or speakers, a common cause of this is reversed speaker polarity.
The wires between the + and - terminals of the speakers MUST connect to the same + and - terminals on the back of the stereo amplifier. The speaker wires that came with the stereo are color coded to help prevent mis-wiring. If you did not pay attention to this or used different wires for any reason, you need to ensure that the wires between the each of the speaker's 4 terminals connect to the correct group and + / - terminals on the amp.
See page 6 of the manual here: https://support.panasonic.co.nz/docstore/SC-EH780%20Operating%20Instructions.pdf
Make sure that the surround and center speakers are connected correctly, too.
Apr 06, 2014 | Technics SC-EH780 CD Shelf System
Technics sc eh600
Check the integrity of your speaker wire, make sure they are 'phased' (-+) properly, also check all other connections, it sounds like the protection ...
Nov 25, 2013 | Audio Players & Recorders
When I play a tune there seems to be no base coming though even tho I have replaced the stylus's
Are you speakers configured correctly? The receiver may have bass turned off, or lowered. I doubt it is your cartridge.
May 15, 2011 | Technics SL-1210 Turntable
What is Phasing and how to set it up
he phase control will help the sound waves from your sub get synced up with those coming from your main speakers. If they arrive out of phase, there's the tiniest delay between **** Jagger's voice and Bill Wyman's bass, for instance. An easy, accurate way of setting the phase control is to reverse the connections on your main speakers (the black wire goes to the red terminal and the red wire to the black terminal). Now play a simple selection, like a jazz instrumental with a good walking bass line, on your system while you're sitting in your listening position. Have a friend dial the phase control on the sub until you hear the least amount of bass. Leave the setting there. Returning your speaker wires to their proper places will now allow you to hear the most bass from your sub.
Oct 05, 2010 | Velodyne CHT-10 Subwoofer
Tape deck not working on a technics rs-eh600. Small belt has slipped off, need advice in putting back on.
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Apr 02, 2010 | Technics Audio Players & Recorders
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Technics manual sleh600
Technics SL-EH600 is CD changer, which is part of SC-EH600 syste, so download:
SC-EH600 Manual, scroll to pages 18-21 for SL-EH600.
Feb 24, 2009 | Technics SCEH790 CD Shelf System
GETTING BETTER SOUND QUALITY
An equaliser is, put simply, a more complex tone control, giving you the ability to cut or boost more specific frequencies than a tone knob, or bass & treble controls.
It comes in handy for tweaking the sound from your hi-fi to just the way you like it. But beware, as it can make your hi-fi produce sounds that are so bass or treble heavy, that you can damage your speakers if you're not careful.
Adding another compnent into the chain (like a graphic EQ) can add a little background noise but this Technics EQ is a pretty quiet one & you probably won't notice the noise apart from when there's no music playing & you've got the amp turned up high.
Jan 10, 2008 | Technics SH-GE70 Home Equalizer
Icbm 779
If there is significantly less bass even though the speakers are moving approximately the same as before, you may have one speaker wired out of phase. Disconnect one speaker. If the bass increases, double-check your wiring.
Nov 17, 2007 | Performance Teknique ICBM-779 Car Audio...
Panasonic 600W DVD+VCR Home Theater System SC-HT822V System Logo
180 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
