I have a Lexmark x5630 printer. And have refilled the cartridge, Now it stills wants me to replace the cartridge. Is there a way around the problem?
    Novelist:
  • 112 Answers
I have been told that some Lexmark printers seem to need a couple of installations B4 it resets.
Posted on Oct 11, 2010
Lexmark service center
Hi Grace,
The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
Regards,
Sean
Nov 26, 2013 | Office Equipment & Supplies
How can I make printer recognize refilled cartridge on lexmark prevail pro 705
Refilled cartridges will not reset the ink levels. The printer will still recognize it as empty.
Please be advised that refilled/remanufactured cartridges could damage your printhead and will not be covered under warranty.
Nov 27, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
Feb 14, 2012 | Lexmark Office Equipment & Supplies
I refilled the cartridge but it still willnot print
Please note that Lexmark does not recommend use of a refilled cartridge. Refilling a cartridge can affect print quality and may cause damage to the printer. For best results, use Lexmark supplies.
You may try to re-insert the cartridges and make sure they are seated properly or clean the cartridge nozzles. Manually wipe the cartridge nozzles with a slightly moistened soft cloth to clean it from possible dirt and clogs. Then, reinsert the cartridges in to the printer. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please replace your refilled cartridges with new genuine Lexmark supplies.
Sep 19, 2011 | Lexmark X2600 InkJet Printer
Hi I have refilled my Lexmark X5630 , BUT IT STILL SHOWS THAT THE CARTRAGE NEEDS TO BE FILLED ;PLEASE ADVICE
Lexmark does not recommend the use of refilled/remanufactured cartridges. They tend to degrade print quality and printer/cartridge performance.
Note that once a cartridge is refilled, it can no longer register its ink level.
Aug 31, 2011 | Lexmark X3650 Printer
Lexmark X5630 indicates refill black and color cartiridge
Is your ink still comming out of the cartridge? if soo than the person who has refilled it hasn';t done it carefulkly and might have damaged it.
I should suggest you to buy a new one......
Apr 28, 2010 | Lexmark X3650 Printer
Refilled ink cartridge and printer tells me to replace cartridge
its impossible trust me,there is some kind of microswitch in the cartridge that tells the printer its empty-now then listen up-refill it before its empty and it will not know,hows that for a work around
Feb 25, 2010 | Lexmark X9350 All-In-One InkJet Printer
My lexmark will not work with refilled ink cartridges.
Lexmark is one of the best printers, Look to see if the heads on the printer are clean. Unlike most printers Lexmark cartridges dont do the controling, the printer does. My son replaces the cartridges, he doesn't refill because of the problem simular to yours.
Mar 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
"color cartridge replacement required"
This is common problem with lexmark cartridges they detect refilled cartridge you need to clean the copper contacts of the cartridge and then insert it if it still shows " color cartridge replacement required" message then you need to buy original color cartridge.........
Jul 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
238 people viewed this question
k24674
jasbo
jasbo
