Question about Cameras
I need user manual to Eyeview Xpower M5pob-1 speed dome outdoor camera. Thank You.
4 Suggested Answers
  • 12 Answers
SOURCE: I need software
Any software will work just get a free one off the net
Posted on Feb 27, 2007
  • 146 Answers
SOURCE: I need a user manual for a Doro NeoBio 25R +1
go to: http://www.doro.com/global/businessunit/doroHOME/Product?c=1000&p=NB25R then go manuals
Posted on Jun 27, 2009
  • 102366 Answers
SOURCE: how do i do this
You can download the manual from the manufacturer's web site at
http://www.svp-tech.com/drv/12v/UserManual.zip
Posted on Jan 24, 2011
Easy outdoor space dome climber assembly manual
Meijer seems to have the manual--same model number as at Amazon, for example.
http://www.meijer.com/assets/product_files/pdf/Gym_Dandy_Impex_Space_Dome_Manual.pdf
Apr 07, 2013 | Impex Easy Outdoor Space Dome Climber
Manual for a northwest territory portland dome tent 17' X 9'
I NEED POLES FOR THIS 17 FT X 9FT NORTHWEST TERRITORY PORTLAND DOME TENT SAYS IT SLEEPS 8 PEOPLE AND HEIGHT IS 70" IT SAYS NEXT TO THE UPC BAR CODE IT WAS MADE FOR KMART.
I CALLED KMART THEY SAID SEARS.COM HAS SOME REPLACEMENT KITS THAT WOULD WORK THERE IS LIKE 8 DIFFERENT KITS. COULD SOME ONE TELL ME WHAT KIT WILL WORK WITH THIS TENT. THANK YOU INADVANCE.TIM
Jun 01, 2012 | Sport & Outdoor - Others
#WMT-5100 PENTAGON 3 DOME CONNECTION TENT MANUAL
Need instructions for the WMT-5100 3 dome tent.
Apr 08, 2012 | Sport & Outdoor - Others
I have 14 camera's plugged in to this system, when I plug the 15th in, I loose a camera, it doesn't matter what port I plug this camera in, nor does it matter ho many camera's are plugged in....
Hello mrfredlockey,
Welcome, and thank you for using FixYa!
To answer your question:
Running these units on passive video power is what is killing the last camera.
The system is rated to run 15 cameras on passive power, so long as you have a true 110vac on a 25 amp circuit.
If you are running 110vac on a 15amp and truely only get 105vac from the circuit; it will dump one of the cameras due to power loss.
Pick one of the cameras that is close to a seperate power source, and wire it to independant power. That should give you the power you need to wire up the 15th camera. Another idea is to switch them all over to a 25amp circuit instead of a 15amp.
Have a great day!
Sep 12, 2011 | Samsung GVTPC16PS Unshielded Twisted Pair...
My screen on the panasonic pv-gs19 is grayish, i can see video in the viewfinder, but not the flip out screen
It is in the Eyeview settings. You need to follow the instruction manual of its setting
Mar 08, 2011 | Cameras
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
May 09, 2009 | Olympus OM-2000 35mm SLR Camera
My view is all black
No offense. Did u check if the camera was set on eyeview or LCD? Please check. sometimes ppl just forget to change the viewing from eyeview to LCD and panic. If it's working at eyeview and not working in LCD mode, plz get the LCD checked. Gud Luck
Dec 11, 2008 | Fuji FinePix S7000 Digital Camera
I need software
Jan 13, 2007 | Eyeview Electronics Electronic Digital...
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Cameras Logo
322 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
