Question about Le Creuset Kone Electric Kettle
Hi,\r\n I have a traditional whistling kettle from Le Creuset. Recently the 'whistling' section that sits on the spout has come loose thereby preventing the pressure within the kettle to be significant enough to allow the kettle to 'whistle'. Do you sell spare parts that could replace the whistling section please? Thanks.
    Champion:
  • 248 Answers
Web search-le creuset kettle parts-or try-searspartsdirect.com
Posted on Oct 12, 2010
Le Crueset 1.8-Qt. Enamel on steel whistling teakettle u-shaped metal piece fell out
There are two parts to the whistle - the hinged whistle bit and the black base that is attached to the spout. They are joined by a pin that passes through the base and through a bracket that is fixed above the spout, and through the bottom of the arm on the hinged whistle. Remove the pin - it is a push fit - so you need a rod of the same diameter. It will then all come to pieces. The U shaped metal spring sits in the bracket on the spout - the open end and the slope on the spring to the top. Then put the bits back together and replace the pin! This is tricky but do-able as all the holes have to line up. You need to have plenty of light to see what is going on. Once aligned the pin goes back in okay but don't try to force it. If it doesn't go in your alignment isn't right.
Mar 22, 2013 | Le Creuset 1.8-qt. Enamel on Steel...
Le creuset classic kettle replacement whistle
The replacement whistle for Alessi 9033 kettle allegedly fits Le Creuset classic kettles. See the customer comments on amazon. The only other replacement I've found is a genuine one on UK ebay.
Jan 29, 2013 | Kitchen Appliances - Others
The whistle does not work, any ideas on a fix?
Check if there is any blockage in the whistle. the whistle will not blow if there is a leak in the steam.so check if the lid is closed tight. There mite not be any big problem.
Thanks for rating Good luck
Dec 23, 2010 | Le Creuset Q9212.67 Electric Kettle
Used my pot, scrubbed with scratch free sponge but the bottom is grey! is it still safe to use
Is it an enamel pot?? If so, yes its fine to use - after time all enamel pots do get a 'worn look'!
Nov 06, 2009 | Le Creuset Q9500.67 Electric Kettle
Smell and taste from water after it has been boiled in kettle. Water from tap, or boiled in a pot has no taste or smell. We are ina soft water area and have no limescale. anyone else complained?
It must be the kettle causing the problem from what you say. If th e kettle is new the problem should reduce with use but if it is old it will get worse (possibbly due to rubber washers/seals perishing)
Oct 17, 2008 | Le Creuset Kone Electric Kettle
My oval Le Creuset dutch oven is cracked on the side. Any way to fix it?
Yes there a foundation repair solution that should repair it sufficiently. Check at Home Depot or Lowes. Any hardware store should be able to help you out.
Sep 03, 2008 | Le Creuset Kone Electric Kettle
My detatchable kettle is not getting electricy from the cord to the kettle
If you are in the UK it could be a blown fuse in the plug, if not a loose wire or contact in the base..
Jul 21, 2008 | Le Creuset Kone Electric Kettle
Le Creuset Kone Electric Kettle (apparently)
no because it isnt realy safe to do that because the tape can melt
Nov 27, 2007 | Le Creuset Kone Electric Kettle
Le Creuset Kone Electric Kettle Logo
976 people viewed this question
Top Le Creuset Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Le Creuset Kitchen Appliances - Other Expert? Answer questions, earn points and help others
