Question about Whirlpool Duet GHW9150P Front Load Washer
Duet 4.4 Tumble Fresh Is locked up and the no response to buttons. Screen says F 21
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet..F with flashing 21 on screen.
"F21" is a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. NOTE: The "SUDS" error can also commonly occur with the F21 error code as this is usually generated when air is sensed in the drainage system.
If the door remains locked (even after unplugging the washer for at least 30 minutes), the following link will explain how you can access the manual release to open the door: http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed You will need to remove the toe panel in order to access the pump. While you have the panel removed, you can easily access the manual release (if required). If you have any questions about these repairs, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Oct 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: unresponsive control panel- Whirlpool duet dryer 4 years old
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Posted on Sep 30, 2010
My whirlpool duet tumble fresh washer washes fine rincing fine but would not spin dry it just agitates
We would advise to contact Whirlpool Customer Service at 1-800-253-1301 for information regarding service that may be needed on the Washer.
Aug 22, 2016 | Whirlpool Washing Machines
Why does my WFW9450WW00 Duet Tumble fresh 4.4 dispense the softener with the detergent
Have you Cleaned the dispenser drawer. Remove the drawer and clean it thoroughly in the sink with warm water making sure all residue is removed. The take a damp clothe and clean the top of the housing where the drawer goes. Let me know after doing that if you still have the problem.
Jun 02, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Unresponsive control panel- Whirlpool duet dryer 4 years old
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
The only button that will respond is
with controls unlocked, you can not power on or start? ck to see if you can get to diagnostic mode.
old duet(red leds) -select drain/spin cycle, no spin (modifier), press prewash 4 times in 5 secs. all lights come on then displays codes, f code are faults
new duet/sports(green leds) - press and hold any one modifier button 4 sec on 4 sec off 4 times.
control boards are common on whirlpool.
Mar 15, 2009 | Washing Machines
Front Loader - whirlpool - does not star
machine controls may be locked. Power on the unit and hold in the far right button for 4 seconds and then try to select settings and cycles
Apr 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,163 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
