Water is leaking from under the fridge
If your chest refrigerator is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty refrigerator but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting
There are not that many serviceable or changeable parts inside a refrigerator. A refrigerator works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a refrigerator but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting
Remove the contents of your refrigerator and place them in an alternative area to keep them frozen. Unplug and defrost your chest refrigerator before you do any troubleshooting or maintenance. Wipe and clean the inside of the refrigerator so that when you plug it back in it, will free of any grime or loose bits of debris. A clean refrigerator will also help to promote visibility when it comes to fixing leaks.
Where is the Leak?
Once you have defrosted your refrigerator, you need to establish which part of the refrigerator the leak is coming from. It could be coming from the inside of the refrigerator and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the refrigerator. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the refrigerator. You will probably have to unscrew or un clip the backing panel.
Check the Drain Hole
If the drain hole on your refrigerator has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest refrigerator. The drain hole is a component within the lower works of the refrigerator through which excess water runs to be recycled.
Compressor Issues
Your refrigerator contains a compressor which evaporates the excess water from the refrigerator. The refrigerator will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new refrigerator.
Thermostat
If your refrigerator is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your refrigerator is cycling correctly prior to making changes or altering the thermostat. Only if the refrigerator is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your refrigerator and you still cannot locate the leak, calling in a service technician might be the best answer.
Hope this will help in solving....
